How Easy To Intall Dish?
dasteelman
85cm transparent dish
85cm Penta Dish (motored)
Black Ultra LNB
VU+Solo
VU+Duo
technomate 9100 linux
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
I intend to install disqec motorised 80cm dish. I have instaled fixed dishes before...so I know about elevation, the clarke belt etc......I have looked on the net and found some basic step by step instructions to instaall a motorised dish.
Is it easy enough ...or should i leave it to the experts? which will cost money
Razor
Retired Mod
Ireland
I also have done the odd fixed dish, but called in an expert to do my motorised system. If you are braver than me have a go yourself and if you fail, then go to plan B.
Yes, have a go, an 80cm on a DiseqC motor is relatively straightforward and there is loads of help available here. :)
G
GotMyBusPass
@ dasteelman
As rolfw mentions, it is relatively straightforward, basic/initial rule is that your mounting pole must be dead plumb in all directions.
T24 has written some helpfull instructions and advice under Tutorials & How To guides further down on this board.
GMBP:)
dasteelman
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
cheers guys,
unlike Newsgroups, you guys dont get angry with some of the basic questions people like me have to ask...thanks so much.
Flattery will eventually get you into trouble Razor :p
dasteelman
Black Ultra LNB
VU+Solo
VU+Duo
Quali-TV (4:2:2)
Eaglebox
UK nds card
Tyne and Wear
hoiw much would it normally cost to install an 80cm system in the uk?
caretaker
i live in the north and i was quoted £200/300 for installation ....and it was my own dish ..so i did it myself...overall it took two good daysO-Ha
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Go for it dasteelman if you take your time and follow the instructions its not that hard.
But as Gmbp says make sure the mounting pole is dead plum in all directions.
Best of luck and remember there is always plan B.
