How to calculate depth of satellite dish?
italy2006
starsat
iran
I have an 110 cm offset dish with smaller wide 100.its depth is 9 cm. Now I want to know how many centimeters the depth of a 30 cm dish is.Please help me.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
So you have 110 hight, 100 width and 9 depth (at the middle? or maximum depth?).
30cm = width, I presume?
Then multiply everything with 30/100, so with 0.3:
33 hight, 30 width and 2.7 depth.
That would give you a dish with the same LNB viewing angle (normal LNBF for offset dish).
But of course you could have a 30cm dish with other paraboloid characteristics, which have a different depth.
So there are other possible answers, depending on which is the relevant criterium.
So, why do you want to know?
Greetz,
A33
italy2006
starsat
iran
I want to extend bigger width of this dish to 130 and smaller width to 120 cm with aluminum sheet. so I want to know is new depth of this enlaeged dish is a standard and correct depth or not. AS you know new depth certainly will be more than 9 cm.
a33
XSAT410
Rebox RE-9000
The Netherlands
When you now have measured depth at the middle, and you want to add exactly 10 cm dish surface around the dish, maintaining the paraboloid form of it (Is that what you want to do?),
then the dish doesn't have a 'flat face' anymore, and the 'depth' measure will be different, horizontally and vertically.
Apart from that, the LNB viewing angle will become bigger ~ do you have a matching LNBF of feedhorn for that?
Otherwise there won't be much benefit from the augmenting.
So I still don't understand what it is exactly, that you want to do and achieve, I'm afraid.
Greetz,
A33
vma
Portugal
vma-satellite.blogspot.pt
RX: 3 motorized DiSEqC-1.2 dishes (100cm, 110cm, 120cm) + 7 regular dishes.
Main receiver: Vu+ Duo + many others & IRD
TX: Modulators for DVB-S/C/T + Dektec Modulators
Field Meter: Emitor, KWS, Kathrein, Unaohm, Promax, Spaun, Rover Instruments, ...
Portugal
A dish is calculated so that the focal distance is compatible with the beam angle on the LNB feedhorn.
The curvature of the dish is calculated like this:
z = (x ^ 2 + y ^ 2) / (4 * fd)
Where X, Y and Z are the 3D coordinates of the dish surface (a parabolic shape) and FD is the feed distance.
If you want to increase the size of your dish, that would be easy on a prime focus dish, as you would have to just "continue" the curvature of the existing shape in a tangent manner.
But if you have an offset dish, that won't be that easy, because all around the dish you will have different curvatures. An offset dish is actually a cutted shape from a bigger parabolic 3D surface! Imagine taking a sphere and cutting it at an angle with a plane. The resulting "slice" would be your offset dish.
The dish is, however, not a perfect sphere, because it would be too big (in Z - think of "too fat"). This is why one uses a parabolic shape, which gets you a big diameter on a relatively flat dish.
The magic of geometry is that no matter where the beam hits the parabolic surface, it will always be reflected to the focus - the LNB. But the even greater magic is that the distance of each beam to the surface of the dish and then reflected to the LNB will always be the same, which is why the signal is in phase!
If you try to increase the surface of your dish by adding to it on the borders, chances are you will get the wrong deometry and the reflected beams will either be off from the LNB or, if they do hit the LNB, they will be out of phase and as a result you will have a worse reception.
Building big size dishes is actually quite expensive and complex due to the fact that the sheet metal suffers both a plastic and an elastic deformation inside the press tool. The elastic deformation causes the dish to spring back when extracted from the press tool - the geometry will be wrong.
A good (and expensive) dish will be produced by trial and error on the press tool, so that the shape of the press tool is exagerated in order to compensate for the elastic deformation. Or, expensive simulation software is used to calculate the theoretic shape.
Using the above formula I wrote many years a go an application to automatically calculate the 3D surface of an offset dish. You only had to input the desired dish size and the tool would calculate and create the surface on the attached CAD software. This was developed for a dish manufacturer.
Regards,
Vitor
RimaNTSS
Some SAT-related hardware.
N-E from Riga
IMHO best way to increase size of dish is to buy the bigger one. All other methods are not good enough, especially in Ku-band.
Why get complicated when SatLex's computer does everything!You have everything there.
italy2006
starsat
iran
hi
is the degree of cuvature a 110 and 130 cm offset dish same? I added aluminum sheet to an 110 cm dish and converted to a 130 cm offset but no signal increase.why?
italy2006
starsat
iran
Regards,
Vitor
I designed dimension of a 130 offset dish y autocad software plotted on the paper and then put it on aluminum sheet and cut sheet according to plan. after that I connected sheet to 110 cm dish with glue. didnt change lnb position but no signal increase. why such failure?
  • 110.pdf
RimaNTSS
N-E from Riga
why such failure?
Because it is nearly impossible to get such an extention in perfect shape. At least it is imposible at home. Secondly, when you do extension you also need to change the feedhorn of the LNB, namely to make the illumination angle of the feedhorn wider. It would be much easier and better to change the dish to bigger one.
The beam angle of the existing LNB is such that it will receive signals only from the original area of the dish when located at its original distance from the dish face, and so you could try extending the feedarm so that the original LNB can now receive signals from the whole of the extended area of the dish (at least, I think that to be the case).
S
Sleepingwiththefish
When I bought my used famaval 2.4m it also came with the extension petals. I never intended to use them and probably never will, some need some work and I think they make the dish too vulnerable to strong winds, but what I wanted to say is that when installing the dish for the first time we hold by hand some side petals in place and for our surprise the signal was significantly stronger without touching the LNB :confused
a33
XSAT410
Rebox RE-9000
The Netherlands
... and so you could try extending the feedarm so that the original LNB can now receive signals from the whole of the extended area of the dish (at least, I think that to be the case).
As the focal distance doesn't change by adding dish surface, I don't think you'd get more signal by putting the LNB out of the focal point.
Edit: However, I remember testing LNB distance with an LNB that was OUT of the focal point, and there wasn't much signal difference. So maybe there could be a little improvement of signal by doing that. But never an improvement that would match the surface augmentation.
And it is not ideal, to have the LNB feedhorn out of the focal point....
@italy2006 :
As I already wrote:
Apart from that, the LNB viewing angle will become bigger ~ do you have a matching LNBF of or feedhorn for that?
So, as you obviously like experimenting: are you gonna make a matching feedhorn for your augmented dish?
Greetz,
A33
italy2006
starsat
iran
@italy2006 :
Greetz,
A33
Tnx.I dont have feedhorn. what is best feedhorn for 130 cm dish or how to make it because no feedhorn here in the market.
a33
XSAT410
Rebox RE-9000
The Netherlands
Well, parabolas I understand a little, since I made my own (offset dish) calculator.
Feedhorns I don't understand.
Nor do I know a way to calculate the opening angle of a feedhorn.
So sorry, but that is way beyond my knowledge... :(
Greetz,
A33
RimaNTSS
N-E from Riga
There are no feedhorns for 130cm dish. Main parameter of the feedhorn is it's illumination angle. In ideal situation illumination angle of the feedhorn should be equal to antenna's opening angle. So, first you should know what was your antenna opening angle. Do you know the opening angle of your antenna before modification and after modification? I think it could changed for some degrees, for example 10*. Therefore I would say that changing of feedhorn (if you manage to find or make one) will not change a lot. The main obstacle why you can not get considerable increase of performance of your system is the fact that it is impossible to make perfect extention boards. It is also nerly impossible to attach those boards to the antenna. So, IMHO, I would say that it almost does not matter what kind of feedhorn will you use you will never get much better performance of the system. At least till you get extension boards perfectly curved and attached to antenna.... but that is impossible, IMHO again. Do not forget, it is Ku-band and any unprecision of shape of antenna > than 1mm is no go.
BTW, I did not see any pictures of your enlarged antenna. Did you show some?
Added later: @italy2006 from your PDF picture I see that you wish to make extension only upwards. So I have couple of questions to you:
- Are you willing to change not only working area of the dish but also it's offset angle?
- Where do you point your LNB? Could you show that point on your PDF drawing?
vma
Portugal
Portugal
The extention you did is for sure completely out of curvature!
It would be a miracle if you would be able to attach aluminium foil to the upper part of your 110cm dish and make it bigger, lets say 130cm. The surface would have to have the exact curvature, which is parabolic. What you modelled by hand is probably just a tangent continuation, which is wrong.
In fact, if it is wrong in the wrong direction, you would actually get LESS signal than without the additional aluminium foil!
Also, for Ku band, I find it hard to believe that within Europe there is any signal you would get with 130cm, that was not already receivable with 110cm.
Look at my profile picture: it shows a "dish" made of aluminium foild and a feed made with legos. Start small with a 30x30cm foil and hold the LNB in front of it. Then start increasing the area. You will see that it gets increasingly more difficult to do a propper dish!
Regards,
Vitor
