Hybrid lnb
mill9
Technomate Tm-7755 + 13/19/28° - PC Pentium Windows XP Pro
Are all the Sky hybrid LNB's width smaller than a conventions LNB for non Sky dishes. In other words will one of these Hybrid LNB's fit a non Sky dish?
All lnbs will fit something with the right packing around the clamp.
mill9
IRateDucks
Sky HD+ 4 boxes running over DVB-T2 Modulators with magic eye support.
Worcestershire
The hybrid lnbs have the same neck size as a standard sky lnb.
daro2096
No setup at present
Consett, Durham
What you need is a wideband LNB with a lo frequency of 10.41. Inverto makes one.
