i need help
Don't know where you are but there are a number of possibilties.
Try: dish not large enough, dish not aligned properly, LNB not aligned, receiver not scanned properly, faulty downlead cable.
Probably more but please give us some information: where you are, what size dish, LNB type, receiver type, anything else that might be relevant.
ford570
hi i have a technomate 5500 ci plus 6.0 lnb i am new to this were can i get the frequencys for this satellite can how do i put then in to the rec
Still need more info...
For frequencies try http://www.lyngsat.com/1west.shtml
Do you have a CAM in your Technomate? If not you will only be able to see the FTA channels which might explain why you only have a handful of channels.
If you don't have the manual for the Technomate perhaps one of the other members can help ou with how to work the receiver.
Some receivers list the major channels on Intelsat707, try scanning that separately
G
GotMyBusPass
Don't you just love it when good advice is offered and no reply or thanks is forthcoming from the poster who asked for help:rolleyes:
GMBP:)
