I want measurements channel master 2.4m dish offset
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Hi all! Questions: Does Channel Master 2.4m (RX version) has the same fitting for lower feedarm like one CM 1.8m antenna? And length of the original CM 2.4m antenna feedarms are ~ 1970mm and 1515mm?
Manikm909
Small'ish Dish Man
Kent, UK
good question ! @nelson_b might be able to answer, as he has both...
nelson_b
Contributor
Hi - RimanNTSS ---- and Manikm909
Im pretty certain the lower feed arm clamp is identical to the 1.8 one ... i will find time tomorrow to measure it.
Regards. .....
Yes, the Rx version I picked up a few years ago had a front end arrangement that was the same as the 1m and 1.2m dishes - ex VSAT -I have been installing.
nelson_b
Contributor
I can confirm that the bottom feed arm clamp is identical for 1.8 and 2.4 dishes ...
its difficult to get a precise measure of the feedarms whilst they are on the dish .... see below my attempt to measure one of the side arms.
RimaNTSS
N-E from Riga
Thanks, @nelson_b So, the long feedarm could be about 202cm (from the LNB-holder to the mounting hole). And the bottom feedarm is about 151cm?
nelson_b
Contributor
Didn,t try measuring the bottom one (more difficult- and it started raining ) will try and look later when the weather clears somewhat ...
nelson_b
Contributor
I do not need precise, just rough size (+/- 5cm). Thanks
Best i can do with the arm in position ..... i also have subreflector arms currently stored in my garage .
Dimensions of the ones here on tape measure. The rx/tx support arms are a completely different length and have no end bolt
