Info please
m 600
technomate 9100
90cm Gregorian dish
West Yorkshire
Hi everyone
I have a 90cm Master of focus dish but nothing to make it move since my Echostar 8700 stopped working.
What do i need to get it going again
You'll need a separate v-box unit controlled by your Technomate's DiseqC control if presumably you still have a 36V motor (actuator?) on your dish.
m 600
technomate 9100
90cm Gregorian dish
West Yorkshire
I have the original 5 wire Fibo motor.
The V box I have seen only have 4 connections
This one has an extra terminal for the +5V if that is what the Fibo needs -
_www.satellitesuperstore.com/vbox.htm
m 600
technomate 9100
90cm Gregorian dish
West Yorkshire
Thanks for the info
Before i buy this Vbox has anyone got one that works with the Fibor motor .
I don,t want to buy it and find out it will not operate the motor
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hi!
the Vbox 3,is the latest modell,of the series!
costs 70€,and support 5 wires,i will order,one next week!
all,other older modells,only support 4 wires!
CROSSBONES
S.Wales
As long as the vbox has +5v output it will work with the fibo motor.;)
Snuffer
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
I you have a box with 4 wires its verry simple to make it 5 wires.
It's only a small modification and can do by every one that can drill a smal hole and solder 1 connection.
