Turok
- Apr 25, 2005
- Age
- 36
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
- Austria
Hello !
sorry,was not @ home
was in my sisters house,and then i have no time,for the internet !
i bought the everything complete in set!
not speratly
,2 years ago,was the last antenna in stock,now the dealer closed his strore,he told me that is the orginal adapter plate from jager,maybe it was not true,never seen the channel master adpter!
so contact jager in taiwain,they must have this part in stock,its part of the EL 1224 System,you only must make the holes,on other places,otherwise,in orginal you can fix it,in iron factory,the do it for me within 5 minutes,2 years ago,then it works,but the problem,with the wrong mount,is always be there,without orginal fibomount and scala,of declination,my dual axis system,will not work like it should be!
in eastern in western satelites,seems to be no one here,to help me to solve this problem
maybe i find a orignal fibo mount for 1,25 m,and then it should work!
on jäger motors i heard,that the have change the production from taiwain to china,now the newer models,are lower in quality,coz inside everything is plastic,and not good quality like the older ones,can anyone confirm this?
sorry i cant go to the roof ,to measure,bacause iam not free from gidiness!
not speratly
