Just got a Philips Gregorian 90cm Dish - help needed
bigup
Penta 85 dish, TM2600 motor, T&K brackets, inverto ultra black twin lnb, vu+ duo receiver
Lancashire
Turok said:
okay,no problem,my version is with 5+ volt modification,
for optical motor sensors!
this the reason why the price is a little bit higher,then the normal vbox,with out modify!
yes, the one i got was the Techomate Vbox2 which also has the +5V :)
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
bigup said:
well, ive just ordered a Invacom QDF-031 quad lnb, ive read on various forums that its very good so thought id go for it to save hassle in the long run. I want to get it done first time :)
Robbo, sorry to ask this question again, but will the QDF-031 quad lnb be a straight swap on my dish?
right, so next is vbox2 and some cabling/bolts
I think so, post a close up photo of the back of the feedhorn without the lnb on, and we can say for definite.
bigup
Lancashire
will do mate :) tomorrow probably though.
bigup
Lancashire
hi guys
i have just noticed the feedhorn on the dish doesn't have the cover/cap on it.
is this needed? i have ordered a Invacom QDF-031 quad lnb, so would i need to use a cap/cover?
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
i dont know is this cap avalible here in europe,call invacom on the hotline,to ask them,normaly the lnb is protectet enough against rain,and waterproof,when the protection ring is installed right!
the technomade vbox i dont know,this the first modell that have the +5 modfy on board,the older ones,in the past never have this,and you have this install separatly,good that is now included,but maybe sillt not on all modells!
search the circular incacom lnb on google,then you see the weather cap what i mean!
what polarizer you want to use?
with this,you can get espasaly on nilesat more signal!
bigup
Lancashire
thanks for the reply Turok.
the lnb i have ordered is the one attached to this post:
NunoV
_____Multi-LNB
_____Enigma2_____
___FIBO_55_90_____
__VU Ultimo 4K___
___ViarkSat4K_____
___Octagon8008__
Portugal
The cover in the feedhorn.
bigup
Lancashire
yep, that is what i do not have!
im hoping the LNB has internal waterproofing! can anyone confirm? Robbo i know you used this lnb, please can you advice?
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
Hello!
here in this auction 380135120323 you can see the slide protection cap of the invacom quad lnb what i mean,its looks with that much more bigger then a normal incacom without!,but i think is only avalible in usa!
Robbo
Retired Mod
Gravesend,Kent,UK
The LNB itself does not need waterproofing as it has a transparent membrane at the mouth.
However, at some dish elevations it may be possible to get rain in the feedhorn, and if it was able to collect at the lnb, you would get no or little signal.
I cannot see unfortunately the feedhorn rain cover listed in satmueller catalogue, just the feedhorn that comes with it.
I think you will have to improvise for a little while, pet food can cover maybe?:-rofl2
bigup
Lancashire
as promised, pics
please let me know if the Invacom QDF-031 lnb would be a easy fit.
bigup
Lancashire
ive found 2 baby food tin covers, but they are slightly too big, am i ok to say "no nail" glue around the feedhorn to i can press one of these covers onto it to make it stick?
or what do you think would be the best way of doing it?
bigup
Lancashire
anyone? robbo can you help please mate.
That certainly looks like a standard C120 mounting.
Robbo
Retired Mod
Gravesend,Kent,UK
OOPs I thought I had replied, but didn't.
Yep, looks OK. Hopefully the screw holes will line up OK too, but the flange and the waveguide diameter look to be correct.
As for the rain cover, you're going to have to play with that, and see what works, but doesn't affect signal. I'd be tempted to bung some tape round it initially.
bigup
Lancashire
thanks mate :)
still on the look out for some decent 5core wire!
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
Try TLC electrical supplies direct. or your local electrical supplier for 5 core wire( tlc will supply it by the meter).
bigup
Lancashire
something like this: _http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Flex_White_3/index.html
"1.0mm 5 Core Pvc - PVC White Flexible Cable 3185Y"
purplemarina
hampshire uk.
I use the 0.75mm 6amp cable on a run of about 20m with no problems (the Vbox max currant 3amps).
MARCO ALMEIDA
stu909 scc909 philips gregorian 90cm
Rotterdam, Netherlands
Hi , i have a hold philips gregorian satellite 90 cm also the positioner and cables ,but i lost the manual and i want to put it back on operation ,do you still have the details connections from the philips manual,i have seen your jpg but i still need cable colors etc..thanks very much ..
