a33
Specialised Contributor
- Sep 24, 2009
- Age
- 63
XSAT410
Rebox RE-9000
- The Netherlands
Ah yes.Hello I retrieved our conversation when I was trying to set up my dish/ motor back in 2017.
Then the 7 degrees on your dish elevation scale is wrong; it should be Bend angle (usually 30/35/40 degrees) MINUS 6.74 degrees.
SG2100 has 30 degrees tilt in motor axis I believe, so in your case set the dish elevation scale to about 23.26*.
Advice Needed - Set up my motorised dish
Finding your first satellite is always tough, and is still difficult, without the right tools. I personally prefer to use a meter, the cheap ones, £5-£10, work perfectly. With these you instantly know if your connections are correct, as the back light comes on, and you can get a signal even...
www.satellites.co.uk
Greetz,
A33
