Marix reloaded help pleaz.
Robotiger
dreambox
Norway
I bought a matrix reloaded and a cas iterface 2.
iinsatld the Cas Interface Studio 6.0 program and tryed many other programs. when i star the program it detect the cas2 programer. and wen i pres on the
cam module programin to program the matrix cam. the cas interfas lamp stops flashing and i gt the message (Detecting CAM ...
Device not detected: 1FFFFFFFFFFFFFFF
For more information goto this link :
http://www.duolabs.com/Faq_tree/Cas2usb/ihaveaproblem/connected/MagicMatrix/1fffffff/menu.html )
If eny one is nown with this error then please help me im still a nob to thouth things. what program is good to use to program my matrix cam using the cas2 programer.??? thx for help.
Dietmen
new
venezuela
The same problem..., I try fixing with CAS3, it doesn't work...Plz Help
PCD
DB Magician
You need to first install driver then cas studio.
