MII+ USB Phønix
hvidehenning
Dbox 500s x2
intel quad core 2
8gb Ram
Asus P5W64 WS Proffesional
Denmark
HI i have a usb phønix programer is it posible to program the MII+ card with this programmer.
Mickha
North West
It should be as you just put the programmer in Phoenix mode and use the MII+ software utility.
Which make/model USB Phoenix programmer have you got?
Some, like the Infinity USB Phoenix programmer, require a serial cable connection to program in Phoenix mode.
hvidehenning
Dbox 500s x2
intel quad core 2
8gb Ram
Denmark
it is the Infinity USB Phoenix
Mickha
North West
Then you need to connect it using both the USB, and Serial cable, to get it to work in Phoenix mode, but as the MII+ card is no longer working, Canal Digital upgraded their encryption, there is little point in programming it, unless you wish to practice how to for any future cards.
