Advice Needed Multistream from 5W
7mdish
Milan, Italy
Can anyone explain what is the difference between Root code and Gold code?
It seems that they have same effect on the received signal. If I have the code I can lock the signal.
Every professional receivers accept only one code and it is the Gold one, no way using the Root code.
Instead, the consumer boxes accept both codes.
I never understood the differences. Thanks.
5.0W_12731 V,29500,8/9,8PSK is also locked with Root code PLS 175803 for all MIS.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
basically the root and the gold codes are the same: every channel work with both codes, it's only a matter of what kind of code your STB will accept.
In this page you can find more info and even a root/gold converter!
Ciao,
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
I tried these but there is no signal. Some info is missing for mine:
What does the Multi 4,5,6 activated(new) mean in :
12605 V,35300,2/3,8PSK with Multi 4,5,6 activated(new). PLS code 16416
Also, what do I put in Roll-off, Pilot, InputStream, and fot T2MI PLP? Also a PLS code on my receiver is a 6 figure number, yet you have given a 5 figure number.
sophie101
* Currently
belgium
Solved: I used the converter to change Root 16416 to Gold 131070, and got a signal lock and lots of Italian channels.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
Advanced users do three manual searches with
InputStream 4
InputStream 5
InputStream 6
PLS code 16416 is = 016416
T2MI is OFF (for multistream)
sophie101
* Currently
belgium
InputStream 4
InputStream 5
InputStream 6
Thank-you Mr Advanced.
Now I know for next time.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Wow over 300 channels. Rai Movies showing a film with Sophia Loren front 1963 ! She's still alive btw at 89
sophie101
* Currently
belgium
Rai Movies is great.
Execpt for the endless re-runs of Laural and Hardy!
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Really what every day, dubbed in Italian I guess ? Not female btw are you ?!
sophie101
* Currently
belgium
Yes, dubbed. They are called Ollio e Stanlio.
Ofc. Does my dislike of Laural and Hardy give it away :-)
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Ah great. Interesting dish setup you have I read. What sat receivers are you using ?
sophie101
* Currently
belgium
I have an edision os mio+ 4k, and a an old Silvercrest SL65 ( dvb-s). The latter is boxed up.
Some history:
I went though two Echostar 3000 ( or a 3600), but these started crashing on some DVB-S channels because it did not know how how to handle some values sent from the TPs. It was a good box because Icould get SECAM from 5W in colour, and RTBF intl plus UK channels in digital. But one box blew up and the other got lost during house moves. Before this I had an analog Sky box from when they broadcast from 19.2, but this box was buried in landfill and has likely decomposed by now. :-)
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Some history:
Aha thanks for the info, I've quite a few sat receivers as my profile shows incl some which do multistream
stcome
3 paraboles motorisées :
SF8008 twin>Grego.90cm offset motor.cde/inverseur
Humax 5000>CM 90 cm offset > Stab 100 / disecq 1.2
TBS5520SE>PC W8.1>Lenson Alu 1m>SJ 5W-45E/Pace 900/TC
77 - France
7:10 p.m. today, disappearance of Italian channels MIS at 5W...on Octagon 8008 and TBS 5520 SE
French channels all OK
Just me ???
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
just cheked no problems with 5W , must at your side
Just me ???
It seems that only for you did the MIS Italians disappear at 5.0W.
I did a test at this position and found that, apart from 11179 V, all Italian transponders are active.
stcome
77 - France
@pipino, thank you, try 11179 V 35300 please
@satesco, thank you, you found the problem: 11179 V is indeed inactive, I hadn't checked the other TPs!!!
Let's hope that the TP "breakdown" that interests me the most will be quickly repaired.
cirio70
Lombardy - Italy
After almost a month of side by side broadcasting 11179V is now turned OFF but the new frequency active is 12605 V (with the same parameters).
Stream: 4, 5 and 6
Bye,
stcome
77 - France
Ciao cirio 70, e grazie.
Thank you cirio 70, valuable information, which completely escaped me.
It will definitely benefit other users.
VIVA Sanremo...:cool:
