My motor setup tutorial
AuldDuffer
Medion 8818 PC with Skystar2. 90cm dish with Astra/Hotbird monoblock and a nice, shiny new Motec positioner :-)
Teesside, North East, UK
Lovely :-) The hammer drill will be waking up the neighbours tomorrow !
alfa155btcc
I have a 85cm Faval Dish with 0.2 titanium lnb and alsat dark motor running off of a Technomate 1500 Ci Super
Bucks
longstockings said:
You should aim to get the best possible signal on the satellite closest to your longtitude which will depend on your location. I just used Thor though and my system works beautifully.
You must ensure
The pole is 100% vertical
That you fixed the dish to the motor centrally
Move the dish up and down / left and right until best signal is achieved
Give it another go but if you can't get it before dusk just temporarily fix your system to hotbird so at least you have something to watch. Go to alsat.co.uk and get the patch for your receiver and weather permitting get it spot on over the weekend.
If I'm around I'll help you as best as I can
Hi There i have just used your sticky thread for fitting motorized diah very very good thankyou very much, the only thing that puzzled me was the pointing at 1W did try this not sure if i did it correctly but i can get hotbird 13, astra 19.2 and eutelsat W2 16, what else should i be able to get with 85cm dish i am in bucks
Thanks Again
your a star
regards
alfa155btcc
:-worship
cliffburnett
Dreambox7025
Pentium4 4Gb Ram - E6600 Proc.
Very good articles thanks,
I think I may be 6 or 7 deg out, to east ?
I'm at 52 Deg North (Banbury Area) - and TM2200 motor instructions say the angle should be 38 Deg.
Having tried the AUto Find on the Dreambox7025 it picks up:
8 deg W - Telecom 2D
7 deg E - Eutelsat
13 deg E - Hotbird.
only got 300+ channels.
When going to around 21 deg E - it actualy looks similar angle to my normal sky dish.
How can you be sure which Sat you are pointed at?
Should I try rotating pole 6 Deg E ? and look for Thor?
So much better trying yourself.
Thanks.
CB
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Perform a satellite scan, or look at individual transponders, see what channels you are actually getting and compare them with what _http://www.lyngsat.com lists
Thor is your closest sat, i.e your nearest due south.
Send the dish there with the dreambox. Do a scan, and see if the channels you get are the
correct ones. If not, then find out which sat it is, and then swivel the motor round the pole accordingly.
neps1966
Dreambox 800hd.
Denmark
Very nice info....
If you set up the USALS and drive to 1W, then when you fine tune the dish to 1W, it should be spot on.
THIS WILL WORK 100%
Thanks from DENMARK
pinhead123
1m dish, dm7025, cas3, diablo cam, dm800, dm600, dm500, dm 7020, and a lot of other stuff
uk
very good tutorial mate,
Well done
regards
pinhead
satnewbie78
i have a fortec star passion plus hd recever with a 65cm dish and a nikkai dish motor
cumbria
thank you soo much for your newbie proof info on setting up a motorised dish did it and worked first time this is a great site thanx to all that post helpfull hits and tips for people like me
thanx again
tomslick
TM9100super X3
90cm Motorised Dish
Cork, Ireland
Super tuturial. Worked super for me after I used 8west for south. 8 WEST for anybody in Ireland not on east coast. Thanks again.
RdMin
Fixed 80cm on 28.2 deg,80cm Motorised 76.5E -58W
Edinburgh, United Kingdom, United Kingdom
Great post,advice spot on.I found the best part was the cup of tea bit!!!..Joking aside it was excellent.
gpoda
Technomate TM-1500 CI Motorised System. Computer Dell running XP and windows 7
And buying a Dreambox
Surrey
Hi guys, I would just like to say a big thank you to everyone for information, I have just set up a new motor for my satellite set up, and I must say the help on these pages was super, I would never have done it without your help.
A big thank you to all,
GPODA.
Thank you (and all the others) for posting your result. It's heartening that we can be of such help.
Jaycee
80 cm motorised dish
Acer Aspire Computer
Fife Scotland
lovala
To be done later.
Yaounde - Cameroon
Please,
Very great tutorial.
My location is Yaounde in Cameroon with coordinates: 3.8643°N, 11.2500°E. How do I locate my due South or nearest due South satellite which can aid me in mounting a jack and positioner for a 1.8m dsih? Thankx in advance.
eagle8411
Starsat SR-X400D with motorised and fixed dish.
Malta
I have installed a new motorised system and can only receive one satellite 13E Hotbird. Let me explain what I did. I have installed a vertical pole whic I made sure it is well upright using a level. Fitted over my motor SG2100A and aligned it to true south (I do not have a compass and maybe I am a bit off !) installed the 90cm dish on the motor and aligned all straight forward. Adjust the elevation and Lattitude to my location as per the instructions within the motor manual. I live in Malta in Marsascala which is at the very South of the island. My Lat and Long are E14.56 and N35.87. Ther motor elevation scale is set to 55 and the latitude scale reads 35. The dish elevation reads 26 approx. Using the startsat tuned to Hotbird could receive the hotbird channels strongly as this should be my highest satellite which is very close to my longitude. But tried to get Astra1D or Badr and no signal received. Appreciate any help in setting up my system. Have read many posts but none seem to work for me.
Rakamo25
Motor dish setup
Northampton
Hi Thor try bbc world 11862 h 2800 you will get good signal
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
Just want to say thank you for this guide, I setup my dish setting the motor to 0 then aligning with Thor 1W and the arc just wasn't spot on. Then I changed to UALS and did what this guide said, drive to Thor 1W then get align the dish and it's perfect!
Glad we were able to help. There's an incredible amount of useful information on this site - seek and ye shall find!
