mischoo
- Dec 1, 2011
- Age
- 40
No satellite setup for the moment. I'm doing some research in order to create a good setup. However I have a cable TV provider in the area, which I will probably use.
I personally usa a Dell Latitude E6410 laptop with builtin SmartCard reader
- I live in an area where the air is so fresh it tickles your nose :D
Hello everyone,
I am currently in process of setting up the whole TV, data and phone infrastructure in my house I have recently finished building...
I would like to discuss with you guys some aspects regarding the TV infrastructure/setup.
Here is some starting info:
Is it any way possible to replace the dumb HUMAX and use the integrated decoder + CAM + Card?
If yes then which CAM, Card and procedure would you recommend?
Many thanks in advance to all
PS: Apologies if my post describes a similar issue with other posts, however my issue is a bit different from what I found so far
- There is one terrestrial TV provider in my area offering digital cable TV services. As far as I discussed with a representative, they offer only some external HD or SD decoders which output to the TV through HDMI respectively SCART
- I have a Samsung P2770HD monitor with integrated HDTV and I want to use the internal receiver instead of the dumb external SD HUMAX decoder.
My Samsung TV device has a CI slot and I was thinking I could buy a CAM in order to still watch the scrambled channels without using their external decoder... - I have been trying to search the web in order to find out which CAM and card to use in order to replace the HUMAX external decoder
- The provider won't offer its customers internal CAMs and neither do they provide any technical info regarding the signal transmission/scrambling/encryption etc...
