New Edision OS nino Pro Grey 1x DVB-S2X + 1x DVB-C/T2 Linux Enigma 2 Combo Tuner Digital Multi-Stream Receiver H.265 HEVC HD 1080p
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
Hope the staff don't mind me posting about this new model, I think there'll me member here interested in this model.
Great spec compact receiver. Two tuners, 1x Satellite DVB-S2X and 1x Hybrid DVB-C/T2. Excellent quality aluminium casing available in 5 matt colours, Grey, Silver, Gold, Rose Gold and White. Comes with a very nice quality universal remote too. Enigma 2, support from OpenViX, OpenATV, Openpli soon. Hardware blindscan support.
Technical features:
- Type: E2 Linux Combo Reivever DVB-S2X + DVB-T2/C with Multi Stream Support
- 1 x Tuner DVB-S2X
- 1 x Tuner DVB-T2/C
- Decoding: H.265/HEVC decoding support
- Multi Stream T2MI Support
- Blind Scan Support
- Enigma 2 Linux operational system
- Processor: BCM73625 Mips Broadcom 742 MHz Dual-Core
- Speed Up to speed 742MHz and up to 2000 DMIPS
- 512MB SLC NAND Flash / 512MB of DDR3 memory
- Video Resolution: 1080p, 1080i, 780p, 720p, 576p, 576i, 480p, 480i
- Full Media Player
- Web Browser and supports HbbTV
- Free Internet Streaming TV and Radio
- WiFi Connection: embedded
- Bluetooth: embedded 2.1/3.0/4.0
- Unlimited channel memory
- Hyper-sensitive tyner for receiving even the weak-signal channels.
- 1 x Smartcard reader
- 10/100 Mbps Ethernet interface
- 2 x USB2.0 ports
- 1 x HDMI 1.4a Connection
- 1 x jack to RS232
- 1 x jack to IR
- 1 x S/PDIF
- Channel switch in less than 1 second.
- Extensive ΕPG and programmed viewing via EPG
- Expandable Add-Ons & Plug-Ins
- Supports Bouquet list
- Multilingual OSD, Skin - support
- Channel search: Fully automatic/Manual
- Time Shift function and Multi Timers
- Supports Teletext & and OSD and VBI subtitles
- Compatible with DiSEqC 1.0, 1,1 ,1.2 and 1.3 (USALS)
- Power consumption less than 0.5 Watt, in low-power stand-by mode.
Available here: Search - nino pro
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I can say the Nino Pro has exceptional blindscan for American Satellites! With SatDreamGr image installed, the Nino Pro can find and process low symbol rates around 800, and it finds transponders that are spaced 2 MHz apart.
What image are you using?
Is there more than one SatdreamGr image ?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Technically, there are several SatDreamGr Image versions. I am using SatDreamGr 6 dated 10-28 with latest online updates.
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
As far as we are aware all the images use the same blindscan function. So SatDreamGR, OpenATV available now. OpenViX due to be released this week. OpenPLi coming soon.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
The images are not the same right now.
All the images should have the same blindscan bin file in usr/bin, but SatDreamGr made modifications in other area to allow for the scanning of transponders 2 MHz apart. As it is now, transponders less than 4MHz apart will not be scanned in the other images. The transponders may be found in blindscan with the other images, but the transponders that are close together will be removed when Service scan starts. Maybe in time, the others will adopt the changes SatDreamGr made. This change effects all receivers. Not just the Nino Pro.
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Dear,
Could you test the sensitivity or the Tuner.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I do not have any electronic equipment that tests tuner sensitivity.
The tuner is sensitive or it would not return good blindscans with low symbol rates.
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
Do you have a link to your git where this change was made?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I did not do the git, so I do not have a link. Should be easy to find though. When a Normal blindscan is complete, the list of transponders found in the scan is sent to Service scan for processing. More or Less, Service scan deletes what it thinks are duplicate transponders from the list and scans the rest. OpenATV images consider anything closer than 4MHz to be duplicates, so those transponders are deleted from the scan list.
Set the Service scan to show the counts of the transponders in the list, and this problem is easy to see (see screencaps).
OpenATV also takes considerably longer to complete the scan ( see screencaps).
This particular problem applies to all receivers with blindscan. Years ago, we probably needed 4 MHz spacing because our hardware was not as good as it is today. But a 4 MHz spacing with the new receivers really hurts the capability or potential.
OpenATV scanned 14 out of 17 transponders while SatDreamGr scanned 16 out of 17. Transponder 3889 was deleted because of transponder 3888 ( 1 MHz apart).
ATV_20181105072637.jpgATV_1_20181105073443.jpgSDGr_A_20181105081446.jpgSDGr_B_20181105081903.jpg
Pierangelo
Italy
@ world of sat.
Please, Could you test the sensitivity of the Tuner in comparison with octagon similar models.
@el bandido you are mistaken about how you think this works. And I know because I wrote that code. If 2 transponders are found, 1 MHz apart and they are not in satellites.xml they will both be saved. The problem occurs on low symbol rate transponders when (and only when) there is already an entry of that transponder in satellites.xml.
Easiest way round the problem would be to use the symbol rate as the sync distance for low symbol rate transponders. If you want to test that I can share some code with you.
Which Octagon models? Only Enigma2 based Octagon with blindscan in that price range is the SF8008. The Octagon has a higher spec processor and is 4K capable, with fast kodi and stalker. But the OS Nino Pro has better blindscan hardware and can even scan MIS/PLS codes.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
@Huevos Will be glad to test anything you have to share. Thanks!
Pierangelo
Italy
I know, but to me sensitivity is the most important features ( Astra 28 with my 150 disk) and I wanted to upgrade from openbox sx4. You can compare to sf4008 4k or sx88+ I have and I know their performances.
It seems that the SatDreamGr image is the image of choice at the moment for small step blind scanning? An Octagon SF8008 loaded with the SatDreamGr image looks to be a good configuration if 4K is required, otherwise the Edison Nino Pro would be the choice if blind scan were the main factor?
