Normal not to reach max levels?
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Hi all,
So this is a question that i’ve been meaning to ask for a while, ever since I went motorised a few years ago. I have a 90cm dish but find that, even on the very strong sats like 13E and 19E, most of the time I‘ll never reach 99/100 SNR levels on channels. Currently on 13E this evening and most channels are around the 78-81% mark (Rai 1 HD as an example). RTPi was one of few that was above 90. on 28E however, I will almost always get 98-100% on the likes of BBC One HD/ITV HD. Is this just the result of a bad installation or normal? I don’t struggle with channels, locking satellites or get any picture break up - but its just something i’ve noticed since motorising my set up. It was the same in my previous property when I had my 80cm dish motorised.
Im using an Octagon SF8008 with OpenATV if that makes any difference :D
Some transponders are so strong on DTH satellites that they may overload your satellite tuner with a large dish resulting in no signal.
Terryl
Custom built PC
This is a digital signal your working with, 100% on all channels is not needed anymore, this is not like the old analog satellite days when you needed every bit of signal you could get, I have great pictures and good sound at 40% on some very weak transponders at ether end on my arc.
And every thing you add to a system adds signal loss, 3 to 7 dB of signal loss can be almost 1/2 of your RF voltage on the system, cheap coax or coax not rated to 2 to 3 GHz can also add to the system loss.
The SNR readings are calculated by the receivers RSSI voltage from the tuner, and all tuners are not the same, you need special equipment to get the true SNR of a system.
MCelliotG
Thessaloniki, Greece
Let me solve your problem once and for all:
And now let me ease your concerns.
You are simply a "victim" of comparing SNR signals in percentages between different tuners and receivers.
Take a minute to ask yourself what you are actually comparing, a percentage level of what exactly? Is there any globally accepted maximum value when it comes to signal that should represent that a digital signal maxes at 100%? These signals are subject to a ratio of useful signal compared to noise called Carrier to Noise or C/N. This produces a limitless value that is measured in dB. Professional tuners, such as the Silabs tuner you have on your SF8008 is more than capable of reproducing and measuring C/N in quite an actualized manner, so changing the value in the menu I show you above from percentages to dB will give you exactly what you actually receive in signal strength.
Usually anything above 14 or 15db when it comes to satellite reception is a significantly strong signal. So compare your signals in dB and you're good to go!
Digital Dreams
My satellite receiver is Starmax A150
West of Iran
Hi
Does the number written as C/N Lock indicate the minimum signal strength (in decibels) to have a good picture?
This amount is only 3.1 dB for the frequency 11919, but it is 9.4 dB for the frequencies 11585, 12380 and 12558. Does this mean that to have a good picture for the three mentioned frequencies, the signal strength should not be less than 9.4 dB?
Thanks a lot
Screenshot_2023-12-04-16-31-17.jpegScreenshot_2023-12-04-16-34-08.jpegScreenshot_2023-12-04-16-32-17.jpegScreenshot_2023-12-04-16-33-24.jpeg
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
That's right. I think that not long ago I had the required min lock until now and this value was only 1db. I'm not exactly sure, but I think it was on the 14w belarushd channel. I didn't believe it and went to try where on the receiver I lose this frequency. and the information on Lyngsat was correct.This is the Locka information - for each frequency separately
Indeed. I think it was 1TV America on 11W in C band. DVB-S with FEC of 1/2 is incredibly forgiving.
In fact, it's still there. It says 2.7dB but this is a little pessimistic.
The Chinese transponder at 10856V on 21.5°E only needs 1.0dB to lock:
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Yes, quite a few of them can be found on satellites with a very low value of Lock.
tom55
TD110
South
that might not be a real C/N value. DVB-S2 specification extended SNR into negative range, -5dB or -8dB not sure of exact value and it all depends on uplink preset
i had channels dropping to 0% in the rain still tuned fine up to certain point when rain got heavy and lock disappeared
most transponders above europe will be lost during extreme weather conditions (Ku band), one exception is a very strong transponder at 5W (~20dB , few cm of heavy wet snow covered the dish and LNB, these channels were still good at 50% SNR
