Wanted Pci-e card for multistream.
blackers
Gibertini 1.25, stab hh120,, vu+solo, tm5402hd, amiko micro hd, sky + hd full sub inc setanta..
Essex Uk
Hi guys I'm after the above if anyone has one they want to sell. Not really fussed on make and a single tuner one would be fine. Thanks in advance.
Sent from my PLK-L01 using Tapatalk
blackers
Essex Uk
Thanks but I can't see a buy option for it.
The cheap one is discontinued - the successor one isnt cheap!
blademedia
Sky
You can still find them with a google search, the successor is cheap compared to most cards that do mutistream, if you have cheaper suggestions please tell us ?
blademedia
Sky
To my knowledge the cheapest cards that do mutistream are as above in my posts. I have both cards somewhere, the next step up in price would be £200 ish for a card/£200 ish for a set top box.
