Picture quality receiver
Messipsa
Astra 19.2
France
Hello
I want buy a New Enigma receiver, and im based only on picture quality, can you help me to choose between thoses receivers basing on picture quality :
1.Octagon SF8008
2.GigaBlue UHD Trio 4K
3.Vu plus zero
4.AX HD60 4K
5.Edision os 4k
Or another receiver with good picture quality, and why
Thank you in advance
I don't see many differences in 'picture quality' between receivers these days. Pick the receiver that best suits your needs. The television and its settings will make much more difference.
Messipsa
Astra 19.2
France
Thank you for response, and in your opinion wich receiver is better from this list ?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Digital in digital out. I don't see any way for the receiver to affect "Picture quality" unless you chose to have it output a lower resolution than the original transmission.
Messipsa
Astra 19.2
France
Thank you for response, this is because i read some where that octagon for instance have a poor picture quality in SD channels, anyway can u in your opinion, technically say wich receiver is better from this list ?
Sorry I have little experience with Enigma receivers. For myself I would choose the SF8008 but only because the manufacturer provides regular updates and has a presence on this site.
The performance of the video scaler can affect image quality, but again there is very little difference as most, if not all, receivers are very good at this these days.
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Too many variables to even attempt to have an opinion. My Zgemma H9s has 16 output resolutions. Did the person expressing the opinion that the sx88 had a poor SD picture try all the output resolutions or did they exp0ect the sx88 to convert the SD to 4k? Was their TV up-scaling?
italy2006
starsat
iran
it seems that here in middle east some receivers using special cpu have lower picture quality than other receivers. like ali cpu
Messipsa
Astra 19.2
France
OK, And technically on the software side, what to choose please ?
Messipsa
Astra 19.2
France
Im in Europe, And technically on the software side, what to choose please ?
The main part that will affect picture quality will be the hardware that controls the HDMI (or other - component / display port) and its maximum through speed, currently around 50Gbps for the highest definition with add-ons.
Size of the PCB in the receiver, the internal and exterior screening (plus proximity to the high voltage parts) will also impact to a lesser or greater degree on the final image shown on the screen.
4wd
Getting the picture
5 W, 9-13-19-28 E
Have not got any modern 4k box (yet, no channels to look at!), with the HD receivers I've used over time the HD always fine but quite some differences in SD (upscaling) quality. So I'd imagine that if one is mostly watching HD (or in the future 4K), any modern box delivers, any differences could be in the way they handle SD.
Choice of new box would be based upon general, daily usefullness, speed, tuner sensitivity, clever functions etc, could very probably buy anyone of the boxes listed by op regarding picture quality. As it stands now, my vu solo2's are still delivering.
Messipsa
Astra 19.2
France
OK, And technically on the software side, what to choose from this list please ?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Personally, I think it is impossible to make recommendations, there are too many variables involved to be realistic in one's visual appraisal, those variables include
Dish type
LNB type
cabling efficiency
suitability of dish location
ambient temperature
EM shielding
power supply stability
tuner capabilities
Display medium
Also your own visual acuity.
For example whilst my wife still is capable of distinguishing between HD and SD she would happily watch SD as HD does little to improve her enjoyment
My wife is the same - unfortunately - and that's why I always have a bit of a problem when upgrading the AV system!
davemurgtroyd
Oxford
Oxford
Picture qu ality is a very subjective item being a compromise between sharpness and motion blur for the same processing power and is very much down to the viewer (and all the other factors mentioned above) so your question is a matter of personal preferences and noone can give you a definitive answer
funtime261
Octagon SF8008, Vu+Duo2. ZGemma H9S, GT Combo, 1.1m offset USALS, inverto black ultra single, Gibertini OP125L , inverto black ultra single.
West Mids
Only thing I would add is if you have an HDR capable TV make sure you buy an HDT receiver.
Messipsa
Astra 19.2
France
OK i understand, in you opinion wich one is good technically for me ?
Messipsa
Astra 19.2
France
Yes i've 4k hdr tv, OK, in your opinion wich one is good technically for me ?
