- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Somewhat related to the earlier thread
Another client with three mini boxes but they do observe the 'switch off one' rule.
They have similar problems where the boxes don't actually revert to a picture unless switched off then on again, usually a number of times.
All boxes are taken off the eco settings, and have been moved around to ensure the wifi signal is strong enough between them and the main box, I have also tried a hard wired connection to one of them, no change.
I suspect it is software issues which might be cured with a firmware update at some point, but I now have four homes booked in the diary with the same troubles, all of which have already had Sky over with no resolution.
Q mini and extenders
Another client has had the Q system delivered to site with three mini boxes and a couple of extenders but no matter where he has fitted them (within 10 meters of the receivers) the signal drops out daily requiring a reset of each device. THey have BT broadband and I will be looking later to...
www.satellites.co.uk
