Receiving oscar 100 narrowband (es'hail2) with my channel master + sdrplay
stephan94
Bavaria
Obviously with a minitioune V2 you have no problem to receive everything.
You have the "receiver" made for that frequency band.:)
Congratulations.:Y
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Congratulations.:Y
Thank you, this is my build, I added a board with RT5047 IC so I can use 13/18v and 22KHz and use it for Amateur DATV as well as feed hunting.
Currently I am testing different LNB's.
Next step will be to transmit, I have a Lime SDR And need to build/buy an amplifier.
125161
Hmmmm, the Philex unit gives similar performance to the Global ADX switch on the normal band limits, though there is no switch to operate the unit in the downconverted range. The LED is permanently lit and upon disassembly there is a missing set of components around where the switch should be.
If anyone does know how these things are enabled, let me know. It is a spare though.
Some imagery of the promotional broadcast with the Global switch. Received on the 80cm Orbital steerable this morning during a dry period.IMG_8650.JPGIMG_8652.JPGIMG_8668.JPGIMG_8680.JPGIMG_8682.JPGIMG_8686.JPG
View attachment 126451View attachment 126452View attachment 126453View attachment 126454
Hmmm, according to the Philex blurb.
Astra 1D converter with RFS -remote function selection. This patented feature enables the converter to be sited away from the receiver, using the polarisation voltage shift that occurs during channel changes to provide automatic switching. The converter is compatible with all receivers that use dual -voltage polarisation switching, including the Amstrad SRD510 and 520. An integral double filter reduces interference from backwards radi-ation. The suggested retail price is £24.95
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Can anyone tell me what image this and how the person has managed to enter the correct frequency ?!
Mini tiourner Express.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Thanks but this doesn't answer my question
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
You have the receiver model and the user's webpage link, what else is causing you difficulty ?
