Satlink ws-6922 reviving
ahmedksal
satlink ws-6922
lebanon
@Trust1, can you please send me file and thanks in advance.
The firmware number on the (screen image of the ) CD is exactly the same as the one your reseller sent you.
Are you certain you have followed the instructions for upgrading to the letter ?
ahmedksal
satlink ws-6922
lebanon
hello, tried to update using the firmware but program stb upgrader does not recognise the bin image file. so please could you give instruction on how to go about doing this the right way. thanks and have a nice day.
Unless there is a hidden reset button on the casing (Perhaps inside the battery compartment) you will need to follow the update instructions within the manual, again, or send it off to your reseller for a repair.
Pages 6 and 7 contain the detail for connection and button pressing.
ahmedksal
satlink ws-6922
lebanon
@Channel Hopper
Sir, as i said earlier meter cannot boot, so how can i enter menu to upgrade or either my english is not up to standard and cannot be understand. there is no reset button under battery compartment. the only advice is on how to program this dead meter through serial to usb cable and what software that accepts the BT_CP09_V1_36_20120427_1416_SATLINK.bin image file. thanks and have a nice day.
Your first post confirms the meter is doing something (blinking lights) , so it is not dead.
What procedure did you use to update the meter first time round ?
ahmedksal
satlink ws-6922
lebanon
hello, first procedure was through usb flash drive. after software finished, mater rebooted and on only 3 light came on without any data on screen. have a nice day.
ahmedksal
satlink ws-6922
lebanon
@Channel Hopper
sir, since last sunday, i have been seeking help on how to revive this meter and all my explanation have been confirmed, but there has not been a single advice or result on how to fix this meter. so please could you explain on what should i do, try my meter away or buy a new one, since my reseller cannot help. i am not looking for free solution if there is one and i am willing to buy it. thanks in advance and have a nice day.
beavs2112
Canada
see signature
London, Ontario Canada
Hello @ahmedksal. Some other meters I have heard of (not mentioning names) don't work after trying to load the wrong software. I do not know the correct procedure for your meter because I don't have any like it. Disclaimer: Warning you could damage your meter so try this at your own risk. At worst you are no farther ahead but it might save you having to buy a new meter. They do this procedure:
1- first you need a USB 32GB or under clean and formatted FAT32 inserted into your computer
2- copy the software BT_CP09_V1_36_20120427_1416_SATLINK.bin or whatever is latest software to the USB
3- rename the file BT_CP09_V1_36_20120427_1416_SATLINK.bin on the USB to flash.bin
4- eject USB from computer then insert USB into meter
5- press MENU key on meter several times while turning meter power switch on
6- follow the instructions like normal for a USB software upgrade
Good luck!
Something in the back of my head keeps suggesting the file needs to be put in the root menu of the USB stick.
That is certainly the general rule when loading f/w .bin files.
ahmedksal
satlink ws-6922
lebanon
@all
thanks everyone for your participation, but i tested the firmware and renamed to bin file but still no luck, seems that i am moving to buy a new meter and will advice my friends to never touch satlink products. looking for advice is to buy another professional meter. have a nice day.
