- Mar 29, 2004
- UK
Yes i have the plate attached to my dish aswell as motor like the one in the pic attached, the only thing i dont have is the superjack arm thing thats in that pic as appentley its not needed, and im currently at work so cant get pic of it, i wish the weather would get better asap
The actuator arm in the picture of the Moteck H180 setup was to provide inclined orbit tracking, it was a LINAK optical actuator with fine resolution.
You are correct, you do not need this, you should have the elevation bolt instead at that location on the setup.
As indicated above by @Mickha you need some type of meter or signal measuring device at the dish during setup.
In the absence of a standalone meter you can use a small TV connected to a satellite receiver at the dish and read the signal level, preferably in dB from the receiver.
Alternatively, you could use a receiver indoors that has streaming capability and stream the signal level from it to a mobile phone that you have at the dish.
Whatever method you use, you need some type of signal level measurement at the dish while you adjust it.
Two things I would consider as mandatory:
1. Digital inclinometer.
2. A means of signal measurement at the dish.
