- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
When you tried the other box, did it work? I guess by the 32% intensity there is no connection to the LNB on the dish. Re-check the cable is properly connected, even try wiggling it a little to see if it makes any difference.
Do you live in a flat or have a shared dish of any kind? Is the dish a standard Sky dish? You could try changing the DiSEqC 1.0 setting to any of the options and seeing if it makes any difference to the intensity level.
