TBS 6983 Low and High SRs
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
The TBS 6983 card is the best card so far and as hard core DXers me (Sato) and Peon (aka Onacila) would like to prove the card`s capability on the following examples. We test our hardware to the maximum on various bands as we can cover C (3.4-4.2 + 4.5-4.8 GHz), Ku (10.75-12.75 GHz) and Ka (18.2-22.2 GHz) plus X band (7.25-7.75 GHz hardware is ready).
Anyway, with TBS 6983 on Windows 7 (32 bit) the lowest SR we have been able to get so far is SR 128 and the highest is SR 60000 KS/s. Both stable and hassle free on a 2.5m prime focus dish by using XMW 9216HDF and NJR 2842S. SR 139 KS/s have been received in C band by using a Norsat 8115F LNB. I guess these are current limits in orbit at the moment, but definitely not the TBS card! If there`s anything under or above those SRs, I`ll post screenshost here asap.
Additional details can be found on lyngsat.com or flysat.com where our and other DXers` updates are posted.
Peon & Sato
Eutelsat 16A @ 16E 21564 H SR 128.jpg Intelsat 902 @ 62E 62E C-band low SR scan.jpg Eutelsat 8West B @ 8W 4153 LHCP SR 60000.jpg Eutelsat 8West B @ 8W 4153 LHCP SR 60000 Multistream + T2-MI.jpg
s-band
Essex
I think it has been posted here before but the card can cover 250-2350MHz. It may do more but mine stops working above 2350 and I can not get streamreader to accept values below 250MHz. I find it useful for using LNBs outside their normal range.
Set the IF limits and IF high/low flips in streamreader.ini (CrazyScan & EBSPro)
;! Change IF range (default 950-2150MHz)
IFStart=250
IFStop=2350
;LNBMid=6000
LNBStk=23000
Calculate LNBMid and LNBStk for C & Ka:
#define IF_FREQM(X) (((LOF>LNB_MID) && (LOF<LNB_STK)) ? (X-LOF) : (LOF-X))
#define FREQM(X) (((LOF>LNB_MID) && (LOF<LNB_STK)) ? (LOF+X) : (LOF-X))
More from CrazyCat in these replies:
TBSDTV Community Forum • View topic - Tuning below 950MHz
mar-val
Slovakia,Zilina
There was a tp at 5E, with SR over 60000, I found old picture of qwer.
And mine ,radio Immac from 16E.
FC GD
Antenna: SelfSat H50D4
Pay Tv: Allente, Telia
Stockholm
old thread here but i want to add some extra information. TBS6983 , it is an old card but a really good one. ive just tested mine and i can confirm that (STV6120 ) it can all the way up till 2450mhz. At very edge it s struggling to get lock. cause it is not seeing the whole carrier. over 2450mhz there is nothing (though the driver alows us to go up up up..)
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
and what inside ?:) some data or radio ?
or test carrier?
satosk
Peon has a designed LNB for this band as well. But he is willing to test this position maybe tomorrow...
He`s playing with Es`hail 2 today. :cool:
FC GD
Stockholm
or test carrier?
First of all CrazyCat , you are my hero ❤️
i just wanted to test my cards limit and generated that datv signal with Adalm-Pluto and DATV Express software. i mean nothing special on 1W (telenorsat is such a borring satellite operator)
satosk
No sign of a "life form" @ 1W in this frequency band was found today by Peon.
FC GD
Stockholm
