Tbs tuner and crazyscan - probably not a pc card issue
stephan94
Bavaria
with TBS 6983 is for me OK
I've tried other versions of Crazyscan and StreamReader.ini files, but anything with the latest StreamReader.dll gives me the same problem.
Using TBS6983. I'll try it on my other PC's Crazyscan with TBS6903, TBS6903X.
I tested the new version StreamReaderEx 1.2.4.126 with Crazyscan 1.0.2.171. Everything is ok.
Try the file with the latest Crazyscan version... 171, used by @John.
I downloaded Crazyscan v.170 a while ago but never used it. Works fine now with the new StreamReader. Thanks.
Hi Llew,
If you don't have Crazyscan v.1.0.2.171, here is the app with all the necessary files(reqlibs,st.reader,etc)
New StreamReaderEx for BDA v.1.2.4.133 from 13.07.2022
frankviana
Satellites/tv
Brazil
I did some tests here, and the software crash after try to tune (same older versions).
But appear new informations and VLC working fine.
Airscan don't show the frequencies too after finish (I need to double click on the chart):
Thx.
I checked Crazyscan2 v.1.0.2.172 at my cable service provider. Never noticed a problem, everything works fine.
To work with TSReader I recommend under Properties->Compatibility to tick "Run this program as Administrator". It is good to enable Compatibility for each app you use.
frankviana
Satellites/tv
Brazil
Are you using DVB-T? Maybe Airscan not full compatible here.
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Set freq step for AirScan to 3 MHz
P.S. update StreamReaderEx-BDA , updated build with same version. Maybe IQScan work now for ISDB-T
CS v 1.0.2.172 also works with terrestrial tv programs for the European DVB-T/T2 system. As such I cannot check ISDB-T :(
CrazyScan2-Air/Cable Scan tool-v.1.0.2.173 from 23.07.2022
CrazyScan2 - Air/Cable Scan tool v.1.0.2.176 (new) from 26.07.2022
CrazyScan2 - Air/Cable Scan tool v.1.0.2.177 (new) from 31.07.2022
CrazyScan v.1.0.2.178 , date 12.09.2022
--Increase max result SR in carrier search dialog
Many thanks, CrazyCat :Y
