Advice Needed Technomate or alsat motor
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Please advice which is better
Good reviews for Technomate on Amazon
Depends what you mean by "better"?
Agreed - but if you go for an ALSAT motor, then get a "Superior Dark Motor" and not a "Supreme Dark Motor - that's cheaper and less likely in my own experience to suffer issues with some receivers (notably any that are"Enigma"/"E2"-based)
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ok thanks
It will be on Octagon SF8008 4K HDR UHD H.265 E2 Linux Dual WiFi Twin
Better means easy to install and reliability
I am leaning towards TM2600 as easily available through Amazon for easier warranty if needed
Ok thanks
Have a read of this current thread before deciding on the TM motor.
funtime261
Octagon SF8008, Vu+Duo2. ZGemma H9S, GT Combo, 1.1m offset USALS, inverto black ultra single, Gibertini OP125L , inverto black ultra single.
West Mids
Had no problems with my TM-2600. Would deffo buy another one. Also with a bit of googling you can get the TM-2600 MK3 for ten quid cheaper than that :)
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
How old is TM 2600
Is it M2orM3
funtime261
West Mids
How old is TM 2600
Is it M2orM3
MK2 I'm pretty sure...at least 4 years old and still works a treat, no play in metal gears even after all this time.
Would deffo buy another. Assume MK3 is even at least as good or better.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Thank you for the detailed information
Is Alsat still running as a business ?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Somewhere on this forum is a thread that lists the various H to H motors and their Asian sources.
I recall the TM design is from the company Moteck, the Dark motors were linked with one of the competitors, Jaeger.
The Moteck from personal experience is much quicker across the arc but has a tendency to corrode, something to consider if you are near the sea.
One clear advantage for me at one time was the wider arc offered by Alsat. Living on top floor flat meant that I had uninterrupted views to the east and the TM just couldn't reach those fringes - even with the hardware limit lugs removed. Alsat one could do 80 degrees in each direction, which meant it was enough to reach 72.1E - but only just!
TM could only reach around 64E. But this is a very specific use case!
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
My old TM 2600 has failed after seven years, but I have a new TM 2600mk3 ready to be installed. I recommend the Technomate any day!!
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Thanks all for your time and advice
I ordered TM 2600 from Amazon
Tony1A
You won't regret it! Great choice! :)
What's the diameter of the output pole (or whatever it's called) on the Technomate motor? Going to motorise one of my zone 2 dishes but anything over 1.5 inches will require a rethink :)
Stub, I believe.
Tony1A
The motor stub diameter is 2 inches.
