Advice Needed Technomate tm-twin 4k twin tuner 4k uhd full hd 1080p satellite receiver dvb-s2
Spiff
Mullion Cove Cornwall
shopingathome.com
Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
I will plug it in after the Tennis & let you know for sure.
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
vokes12345
oscam
uk
hi got Technomate Linux TM-Twin 4K Twin Tuner 4K UHD Full HD 1080p Satellite Receiver how do i get oscam menu on box
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Good evening Vokes12345,
I expect William1 will know.
I purchased a Technomate M3 no 4k but a fast blind scan : )
God Bless Spiff
TM Linux is poorly supported & the software is not very good,
Sorry no support from me on that one.
Mickha
North West
Found this thread:
This thread is from early 2017, which seems quite old, considering how quickly technology changes.
Just had a search, for TM-Twin 4K images and it seems that openvix do support these models, so installing an image, and downloading softcams, should be reasonably straight forward.
Which image do you have loaded?
vokes12345
oscam
uk
Technomate TM-Twin 4K Twin Tuner 4K UHD Full HD 1080p Satellite Receiver DVB-S2
Good afternoon from a sunny Mullion Cove Cornwall, we hope you are all enjoying similar weather : )
I have messaged systemsat_direct but no reply.
Does anyone know if this receiver has Blind Scan ?
I can find no mention of it in the specification.
Another question is if the menu is similar to the TM-5402HD C1+ Super+ ?
It has 4k which I am after, not really interested in the Twin tuner but there it is.
Thank You for your time
God Bless Spiff
hi can you do me big faver bought Technomate Linux TM-Twin 4K Twin Tuner 4K UHD Full HD 1080p satellite how would i tune up box got mono block on my dish for hotbird 13 east astra 19 east where do i go on menu and what setting need on box
Spiff
shopingathome.com
Primesat VBox
2 x Actuators
Amiko Viper4K
Primesat VBox
2 Actuators
Seven Computers : )
Good evening vokes12345,
I did not purchase the 4k box in the end, so sorry I cannot help.
God Bless Spiff
One satellite needs to be set to diseqc 1.0 port 1 or A, the other satellite port 2 or B.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Vokes12345's question continues here:
So I suggest we also continue there.
Greetz,
A33
vokes12345
oscam
uk
Greetz,
A33
Technomate Linux TM-Twin 4K Twin Tuner 4K UHD what do i put on box to tune up hotbird Astra using mono block can you tell me step by step what i need to do
Mickha
North West
Only someone who owns your type of receiver, and has a similar set up, can provide a step by step guide.
What experience, do you have, with any other satellite receivers?
You appear certain that you have a 6 degree monoblock LNB, and that your dish is correctly set up to receive 13E, and 19.2E, but you never answer any questions, just post the same question over, and over, again, and again.
Was this system working, before you bought your new receiver?
Did somebody have to set that up for you?
vokes12345
oscam
uk
yes was working box went faulty bought Technomate Linux TM-Twin 4K Twin Tuner 4K UHD Full HD 1080p satellite how would i tune up box got mono block on my dish for hotbird 13 east astra 19 east where do i go on menu and what setting need on box step by step can you help me
Mickha
North West
Once you've set the tuner up, to Advanced, Hotbird 13E, LNB 1, Diseqc 1.0, and saved the new settings, exit that menu and look for a blind scan option, or a manual scan, and select an appropriate transponder:
https://www.lyngsat.com/Hotbird-13B-13C-13E.html
https://www.lyngsat.com/Astra-1KR-1L-1M-1N.html
Choose a transponder with a Free To Air, red F, that you used to receive.
e.g. 13E 10758 V 27500 DVB-S2 8PSK 3/4
19.2E 11377 V 22000 DVB-S2 8PSK 2/3
Check any channels, you scan in, against the list on lyngsat.
STOP!!!
You are posting the same question over & over again.You need to give folks a chance to answer rather than just asking the same thing.
If the dish was working correctly in the first place with the other receiver then it should just be a case of selecting Disecq A/B in the menu structure and setting the two satellites up.
vokes12345
oscam
uk
Greetz,
A33
hi can you tell me how to do it thanks
What have you actually tried? Asking the same question over and over with no feedback on what you've tried in response to answers given is becoming monotonous.
a33
XSAT410
Rebox RE-9000
The Netherlands
And the same question in two topics.... but even the moderators thought my suggestion above (#32) to continue in the other thread as not helpful.... :(
Greetz,
A33
