Advice Needed Toroidal t90 installation t&k wall or ...?
haveaone
Toroidal T90 multi-beam
northern ireland
HI
I WOLD LIKE TO ASKE WHATS BEST TO INSTALL TOROIDAL T90 DISH
14.1KG /31.0LBS THANK YOU IN ADVANCE.
A good quality elbow type bracket will do, but needs to have braces built in for stability.
4wd
Getting the picture
5 W, 9-13-19-28 E
The t90 is 'immensely' front heavy. If wall mounted, imo only use the 60 mm original mount. Mount only on a very solid wall, strenghten \ disseminate load with horizontal wood boards top and bottom, use properly dimensioned screws (add large washers for extra pression surface at srew heads).
pictures of mount > Wavefield 60mm Pole Mount Single pack (T90)
haveaone
northern ireland
Thank you for your reply, I find I place my dish position I'm not able to use arm wall bracket I'm trying to attach some photo but due to the size I think they are not uploading on the web site
So are you looking at an above the gutter mount? Can't really see from that photo.
TJExcalibur
Out of this world.
Southern England
Elbow mounts are not very good because the fixings are in one position on the wall. Better to use T & K brackets to spread the load.
There are some good ones available, large backplates and braces, more than man enough for a T90, but it looks like they wouldn't be suitable anyway and perhaps T&Ks may be the only answer, perhaps more than one set, or at the least, two K brackets.
haveaone
northern ireland
I'm able to use the WhatsApp to send you you!? xxxxxxxxxxxxxxxxx
MOD NOTE Phone numbers should not be displayed on open forum for your own safety. If Rolf does have WhatsApp he will be able to find the number I have deleted. But what's wrong with posting another photo that's better so we can all see it?
haveaone
northern ireland
Yes I did try to attach the photo but it says it's too large I try different format doesn't let me to upload a photo from my phone or computer any advice please!?
If you've only got a phone and the phone doesn't have an app to reduce the size of the photo then the only other thing I can suggest is what I had to do once. Take photo from a little distance away and then crop the photo to give a close-up.
TJExcalibur
Out of this world.
Southern England
If its on the computer use Windows paint or similar to reduce the size. Or this program does it.
xxx.reduceimages.com/ Change the XXX for www
Also, if you can put it on a PC or similar (I don't "do" Apple Stuff"!) then something like the FastStone Image Viewer App can do that very easily/quickly.
haveaone
northern ireland
HI
TJExcalibur
Out of this world.
Southern England
I used these. better support due to spacing of fixings.
XXX.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Nedis+Universal+Galvanised+Satellite+Wall+Pole+Mount+Bracket+&_sacat=0
haveaone
northern ireland
Thank you I tap on the link doesn't open!
The answer is within the pages of the dish manual, based on your location and what you intend on watching.
haveaone
northern ireland
Hi I wold like to add is much satellite is possible the only thing I bought dish it's no instructions and I never had this tip of dish it's new to me TOROIDAL T90
4wd
Getting the picture
5 W, 9-13-19-28 E
Start by doing some (lots of) reading. Search google, and search the forum here.
example installing t90 dish - Google Search
1st thing will be to make the support absolutely stable, very solid, exactly straight ...or else you will struggle forever trying to adjust a t90.
IMO, do not install at the end of a ladder. Get it a ground\standing level, there will be lots of activity over quite a long period before getting things right, adjusting dish angles, adjusting\adding lnb's, cabling etc.
