Unable to receive feeds on 7E, help please!
Rich83
Technomate TM-5402
Inverto 80cm
Inverto Black Ultra Quad
Technomate TM-2300
London
Hi, I have installed a motorised system for a client. TM-5402 receiver with Technomate Diseqc motor and an 85cm dish. Great reception of all satellites from 0.8W to 33E, aligned with my Promax Ranger Neo analyser.
The client needs to receive the European Central Bank press conference, which runs every 6 weeks or so. This used to be broadcast on 9E and was fine, but since moving to 7E they have not been able to receive it. The broadcast only starts 30 mins before the actual conference. The last conference was broadcast on 11135 H (TP B5). Prior to the start, I placed the dish on a static mount and aligned perfectly for 7E. I could not receive this TP on my analyser. I can see the peak on the spectrum, but there is not enough carrier to noise to receiver (it came through for 2-3 seconds at one point).
I know the answer, bigger dish, even though Eutelsat state in the UK max dish size required for the Europe A beam is 65cm.
My questions are: has anybody received this feed and what dish size is required (London)? And, are there any other regular feeds for nearby transponders I can use for testing, at the moment I have 90 minutes every 6 weeks!
I’d really appreciate any advice, thanks in advance!
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Rich83
Technomate TM-5402
Inverto 80cm
Technomate TM-2300
London
Thanks A33, yes that’s the link I work from - I should have included it in my post, I appreciate your assistance!
Bigger dish needed. Feeds are typically lower power than tv broadcast channels. Plus its possible they are using the B- beam rather than the A-beam which gives good signals in the UK.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Your client could always view this broadcast via live stream directly from the EBU Webcasts: ECB monetary policy decisions .
The FEC is quite low on this transponder so not sure if this could be a factor too. Of course it will be hard to test this broadcast for you while it’s not broadcasting. I have a similar setup but have a 1.1m dish.
Burnham Beech
This fta feed is active at moment
7.0°E
12537 H 7200 4:2:0
ID: BSA-02 E-447 BRODCAST PROD
You need to look at the sаt univеrse forum to get current & active feeds
