UNITRAC Satellite dish
beavs2112
Canada
see signature
London, Ontario Canada
Anyone heard of dishes made in Yugoslavia? An aluminum tag attached to the mount has painted in black (but highly faded now) "UNITRAC U90". I rescued these 2 perforated aluminum (not regular mesh) 3.0m prime focus antennae from a trailer park's mini cable tv headend. They are probably early 80's vintage. Price was good at 0.0$. It's stamped in the steel mount bracketry "made in yugoslavia". Also painted on the steel circular cover in the center of the dish "made in yugoslavia". They should work real good on ku-band also.
Kevin
beavs2112
Canada
see signature
more pics
remlap
Wales
Nice find, honestly reading Trailer Park and Canada made me think of Trailer Park Boys.
mephisto
TBS 5925 DVB-S2 TV Tuner USB
Dreambox 500S
Vantage X221S CICX
Samsung DSR 9500 VIACI
Echostar AD 3000 IP
1,2m offset dish w/polarmount
Inverto Black Ultra lnb 0.2 db
Actuator Superjack 12"
55°E - 30°W
Uzice, Serbia
These are actually produced by MZT (Metalski Zavod Tito) from Skopje, Macedonia under the brand of Unitrac, which suggests that they are maded for export (mostly for Canada and US) and by specifications should by a slightly better (and were a bit expensive) than those maded for the former Yugoslavia market. I got one too, but its a solid one. As for Ku band you can count on a slightly losses in the reception quality because of its mesh (porous) structure. Cheers!
Good to see another unloved dish getting a good home :D
beavs2112
Canada
see signature
Mephisto thank you very much for sharing that info. My searches on the internet had turned up nothing useful previously.
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
If its of some help, here are some old pictures and specifications from the 80s for those antennas from official manufacturer. Unfortunately, pics cant be enlarged, so the specifications may not be so clear to see. :(
mephisto
Dreambox 500S
Vantage X221S CICX
Echostar AD 3000 IP
55°E - 30°W
Uzice, Serbia
My advice for you would be not to disassembling petals and to hold em off in one piece, if its possible, because its pretty demanding to put em back together properly, which can affect the reception quality at the end. Are they with fixed mounts or with polarmounts? Can you post here pics of the backs of the dishes? Thanx in advance
beavs2112
Canada
see signature
thanks for the advice and pics. i brought the dishes home in one piece so that is how they will stay. i am happy to report they are polar mounts. they look exactly like the black ones in your second brochure.
stecle
Edison Mio with 10 foot mesh C-Band
Custom built PC with Intel
Canada
I found the H to H motor that was manufactured by this company. Probably hasn't been used in over 25 years. Hope to refurbish it and put it back into service.
