US power to UK
hillway
db7000 90 CM triax moteck motor
well trying to install it !
NW
hi there have just purchased a DG relook 200
it has has come with a power supply on for the US , can some 1 please help can i just change the plug to a UK 3 prong plug .
can some 1 please advise.
thanks
ukeden
i bougt an old telves box and just cut it off and repluged it all was fine m8
Likvid
Stockholm, Sweden
If it says at the back of the receiver only 110-120v you need a power converter or you will blow your receiver.
2cvbloke
Near Pontop Pike, Co. Durham
Maplin has a good 240v to 110v convertor:
_http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=31899&doy=28m2
JTA
DM8000HD+DM7000S with PLi image, CCcam, movable dish 0.85 m, very happy indeed
Belgium
what about the 60 Hz in the US-of-A ?
Doesn't matter. Only frequency - sensitive devices such as record turntables, clocks etc. may not function correctly.
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
You really need a stepdown converter. Plug it into 230v and BOOM!
CROSSBONES
S.Wales
Hillway, where did you buy it from mate? If you dont mind me asking;) Thinkin of getting one my self.
hillway
NW
hi m8 - got it form a well known auction site ...
make them an offer got it delivered for 60...
have yet to set it up yet though! cause of the plug situation....:-doh2
hillway
NW
to follow up on the plug socket situation - opened up the box the resistor is for 250 v so the USA DG station will allow for UK type plug -
have just replaced with UK plug and all has powered on
just to let u know.
chrissat
Mutant 200s
Skystar 1
80cm dish
uk
Just to let you know,
I cut the plug of my usa box and replaced it with a uk one. Mutant has been working fine for a couple of weeks.
One word of warning, I found my box did not have the socket for the Jtag and I had to solder one on.
