Just Sharing This TM5502HD Motorised Ch List 50 West to 50 East
TBN Ku Band TV Channel list by William-1,
TM5502HD + 100cm dish all satellite transponders updated 10th February 2017
This TBN file can be use with these Technomate satellite receivers:-
TM5302HD & TM5502HD
All Transponders updated on 28.2 east,19.2 east & 13 east most other satellites are up to date.
Intelsat-29E @ 50°west only data streams atm
Updated:-
Intel-14 @ 45°west
Telstar-11N @ 37.5°west "occasional feeds"
Eutelsat-36 West A @ 36°west "occasional feeds"
Intelsat-903 @34.5°west west "occasional feeds"
Intelsat-25 @ 31.5°west
Hispasat @ 30°west
Intel-907 @ 27.5°west
Intel 905 @ 24.5°west
SES-4 @ 22° west
Telstar-12 Vantage @ 15°west
Express AM8 @ 14°west
Eutel-12 West B @ 12.5°west
Express AM44 @ 11°west
Eutel-8 West B @ 8°west
Eutel-7 West A @ 7.3°west
Eutel-5 West A @ 5°west
Amos 2/3 @ 4°west
Thor-5/6/7 @ 0.8°west
Eutelsat 3B @ 3.1°east
Astra 4A @ 4.8°east
Eutelsat 7A/7B @ 7°east
Eutelsat 9B @ 9°east
Eutelsat 10A @ 10°east
Hot Bird 13B/13C/13E @ 13°east
Eutelsat 16A @ 16°east
Astra 1KR/1L/1M/1N @ 19.2°east
Eutelsat 21B @ 21.6°east
Astra 3B @ 23.5°east
Badr-4 @ 26°east
Astra 2E/2F/2G @ 28.2°east
Eutelsat 31A (incl. 1.5°) @ 30.9°east "occasional feeds"
Eutelsat 33C/33E @ 33.1°east "occasional feeds"
Eutelsat 36B @ 36°east
Hellas Sat 2 @ 39°east
Express AM7 @ 40°east No Ku for Western Europe atm
Türksat 2A/3A/4A @ 42°east
IS-12 @ 45°east
AzerSpace 1 @ 46°east
Türksat 4B @ 50°east
Not updated as my 100cm dish only covers 50 east to 50 west.
Belarus Sat 1 @ 51.5°east
TürkmenÄlem/MonacoSat @ 52°east
Yahsat-1A @ 52.5°east
Express-AM6 @ 53°east
Updated
Plus additional satellites & feeds here:-
23.5°east
21.6°east
16°east
10°east
7°east
SES-5 @ 5°east
3.1°east
Intel-10-02 @ 1°west
ABS-3A @ 3°west "occasional feeds"
5°west
8°west
12.5°west
24.5°west
30°west
NSS-7 @ 20°west nothing here atm.
  • TM5502HD Ch List by William_1 for 10th Feb 2017.zip
William,
Thank you for the channel list.
I have a question of you can please help? Do you still maintain the table where you listed the frequency bands per satellite? It is useful when using a TM5302/TM5502 for a blind scan as it allows selection of only frequency ranges that are operational per satellite and reduces scan time. If you still maintain the list would you please be able to upload a copy?
On the subject of a blind scan with a TM5302/TM5502, have you found much difference in transponders received using 4MHz steps or 6MHz steps? As you know, these receivers can be painfully slow and any options to speed up a scan are useful.
Many Thanks
I use 6MHz steps on most satellites when I am compiling satellite charts for 21.6 east & 3.1 east I use 3MHz steps, 10 east & 16 east 6MHz steps,
For the faster Blind Scans split the Ku band into sections,
Most productive 1st on 10 east for example:-
Blind Scan-1 10950 to 11200 H
-------------2 11200 to 11450 H &V
-------------3 11450 to 11700 H & V
-------------4 12500 to 12750 H
-------------5 12500 to 12750 V
-------------6 10950 to 11200 V
-------------7 10700 to 10950 V
William,
Thank you for sharing the list and for your feedback, it is a great help.
Rgds
William,
I am back with another question about the channel list and the TM-5502 if you can please help?
I would like to insert a couple of satellites into the channel list in between the existing satellites. For example, I would like to insert PakSat 1R at 38.0E in between 39.0E and 36.0E. If I take one of the empty satellites at the end of the list in the TM-5502 menu and edit the name and orbital position, will the TM-5502 automatically drop it into the correct sequence in the satellite lists? My hope is that it will but I fear the worst.
Last question, is it possible to get the TM-5502 to present the satellite list in reverse order so that the most Easterly satellite is the top of the list and as the list is descended the list moves towards Westerly satellites with the most Westerly at the bottom of the list. I tried messing around with the Technomate TBN editor but got nowhere except for realising what the file format is for the channel list. It is a binary file, TBN = Technomane BiNary file.
Many Thanks.
I did try the list in reverse with the original software but the DiSEqC motor control was not responsive after I got TM to sort out the Blind Scan this was an achievement as the original Blind Scan was a nightmare,
I did point out to TM that the tbn Editor was next to useless but never got any response,
There are still a few niggles with the Blind Scan when you exit the menu the last transponder polarisation is sometimes changed :eek:
So you just change it back manually,
Also using 3 & 4 MHz steps on some satellites for example 16 east 12500 to 12750 if a low symbol rate below 1600 the receiver will go into a continuous loop & add the same parameters 20 to 30 times or until you stop it,
Last problem to be aware of not all the found transponders will be scanned in the 2nd phase of the Blind Scan so if you saw the transponder added to the data base in the 1st scan just re-scan the missing transponders manually,
I did inform TM of these outstanding issues again no response :( I am just great-full that the Blind Scan is now usable,
The best way to keep the receiver working to it's best performance is to save your channel list periodically on a USB stick & save as Default Channels that actually works on the TM5302HD & TM5502HD,
Then perform a factory reset turn off the receiver at the mains for 30 sec then reload your channel list I do this about every 3 to 4 weeks or if the receiver starts to play up.
To add new satellites just modify my list,
I have begun to experiment with the feed satellites starting at East to West so it may be worth another go a re compiling the list from scratch with the latest software as the editor is useless this will have to be done manually,
I hope this info helps you.
William,
Thank you for the reply, it is very useful. I was not aware of the quirks that you mentioned. There are several plus points about these receivers in that they report the correct frequency and SR and the tuners seems to be quite sensitive. I suppose its a trade off, the good points vs the quirky points.
Rgds
This is my Ku band active feed guide................
Satellite Feeds with a UK / European Beam 53 east to 45 west
The Active part of the Ku band for Feeds by William-1
53.0°E Express AM6
11460 to 11500 V
12500 to 12550 H & V
46.0°E AzerSpace 1
10980 to 11100 H & V
Türksat 3A/4A at 42.0°E
Mainly Turkish News & Sports
10950 to 11200 H & V
11450 to 11640 H & V
12560 to 12700 H & V
39.0°E Hellas Sat 2
11080 to 11110 V
12700 to 12750 H
Eutelsat 36B @ 36° East
Eastern European News & Sports feeds
11640 to 11660 V
12550 to 12750 H & V
33.0°E Eutelsat 33C
11450 to 11620 V
12500 to 12750 V
30.9°E Eutelsat 31A (incl. 2.1°)
10950 to 11070 H
11550 to 11650 H
12500 to 12550 V
28.2°E Astra 2F
12500 to 12690 H & V
26.0°E Badr 4
12530 to 12750 H & V
Astra 3B @ 23.5° East
Dutch German & UK News + Sports feeds
11450 to 11700 V & H
12500 to 12750 V & H
Eutelsat 21B @ 21.5° East
Middle East News & some Sports feeds
10950 to 11180 H & V
12500 to 12750 H & V not used much these days
Eutelsat 16A @ 16° East
Sports & News feeds for Europe & UK
10950 to 11190 H & V
11550 to 11700 V
12500 to 12750 V
Eutelsat 10A @ 10° East
10700 to 10950 V
10950 to 11700 V & H
Eutelsat 7A/7B @ 7° East
Astra 4A at 4.8°E
English & Nordic News/Sports feeds
Eutelsat 3B @ 3.1 east
Arab,English & Spanish Football
10950 to 11190 H
Intelsat 10-02 @ 1° West
UK, Baltic & Nordic Sports & News feeds
10950 to 11190 V
11450 to 11700 V
12510 to 12545 V
3.0°W ABS 3A
10960 to 11100 V
11450 to 11700 V
12500 to 12600 V
5.0°W Eutelsat 5 West A
11450 to 11600 H
Eutelsat 8 West B at 8.0°W
Middle East feeds some Football
12500 to 12750 V
11.0°W Express AM44
11050 to 11200 H & V
11460 to 11650 H
Eutelsat 12 West B @ 12.5 west
Golf,Football ect feeds here
10950 to 11040 Vertical
11450 to 11700 Horizontal
15.0°W Telstar 12 Vantage
11600 to 11700 H & V
12500 to 12700 H & V
20.0°W NSS 7 (incl. 1.6°)
11000 to 11190 H
22.0°W SES 4
10960 to 11170 H
11550 to 11700 H
12600 to 12660 H
Intelsat 905 @ 24.5 west
10950 to 11200 V & H
27.5°W Intelsat 907
11140 to 11180 V
Hispasat 30W-4/30W-5 @ 30° West
Spanish Football & News feeds
11490 to 11700 V & H
11950 to 11990 H
12570 to 12740 H & V
34.5°W Intelsat 903
10950 to 11120 V
11500 to 11700 V
Eutelsat 36 West A @ 36 west
10950 to 11200 (not active atm)
11320 to 11430 H
12500 to 12750 (not active atm)
Mainly Spanish News feeds for Overon but some English Football at times.
Telstar 11N at 37.6°W
10950 to 11060 V & H
11550 to 11700 V
45.0°W Intelsat 14
11500 to 11680 H & V
William,
Many Thanks.
New list with Satellites starting @ 53 east through to 45 west with feed satellites in sequence with extra spaces at the start, middle & end of this new Satellite list made on the TM5302HD+ 88 cm dish it has taken me about 8 hours manually as the channel editor cannot perform these tasks,
I will then load this list on the TM5502HD & re-scan some satellites as this will be on the 100cm dish & issue later today.
