unable to get surround sound from bluray player
If the signals sent from the TV down the HDMI cable are turning off the surround sound setting, it - should - be easy to check by connecting the optical cable directly from bluray to the Sony audio centre, and briefly pulling the HDMI cable out from the TV.
... it - should - be easy to check by connecting the optical cable directly from bluray to the Sony audio centre...
That would need an optical to co-axial (or vice-versa) adaptor though.
Which is what the o/p was looking into earlier in the week.
Removing the HDMI stops viewing of the Bluray setup menu, plugging it into a modern computer monitor will allow viewing of any releasing of the stereo restriction.
The purchase of the adaptor will no longer be needed if the replacement player works as expected so I expect that it will be an unnecessary expense and therefore not happen.
Apart from the expense of a second player.
which could potentially be removed by suitable disabling of HDMI protocol from the TV.
But I think the replacement player has already been ordered and (presumably) paid for.
Luke61
80cm Technomate, Philips twin lnb, Telekom HD receiver, fixed on 39E
Leicester
the sony system is ht-rt3
sorry but could not get it to work and if i would have gotten the coaxial to optical adapter i would have had to move the optical lead from tv to player every time i wanted to watch something so gave up that idea.
good news is i got a new player bd-h6500 and it works fine over the hdmi [emoji4]
so thank you everyone for your help [emoji106]
