Advice Needed modded russian LNB
PrvtN00b
2.4 PF, 1.8 Raven Offset and 1.2 offset for DTV
Panama Central America
anyone here have been able to use one of these modded Russian LNB, are they really worth it?, I can bearly speak english so I know noth ing about russian, can someone explain more about them?
some videos:
Thanks.
archive10
I know no Russian either.
And I do not have any of the materials to hand.
But it seems the white foam bits would seem to work as a scalar.
Similar techniques are used for naroow (aka "bullet") LNBs for close mounting on multifeed antennas.
Unsure of the perfromance relative to a well-tuned feed-horn, but I would speculate that you won't get massive advantage compared to a wel-designed feed-horn.
I too would be interested in what the story being told on the videos are ... do they claim low price, or high gain?
(or miracle reception??)
PrvtN00b
Well the little thing I have been able to understand is that they promise more gain, basically their intention is to eliminate the need of using a scalar ring because with this “revolutionary” design the LNB concentrates the wave and signal better and the isolation material transfer it better to the circuits boards inside reducing lost to more or less minimal.
Anonymous_1
I have one of this LNB at home, received some years ago for a test report.
It works but nothing very amazing , it s a little bit better (link largin) on a part of the frequency range but the gain is not linear and it s a cheap "home made" lnb.
You can forget it, no miracles...
blademedia
Sky
In one of his videos he's showing his C band LNB test on his pc screen he has KU transponders :-lol
It is a modification that normally gets used on a small prime focus dish to reduce the shadow of the scalar feed.
The foam has two properties in this case, providing a better match to the reflector shape than a scalar feed, and to act as a holster for the rivets, which by their shape act as 'stubs', which are also a method of reducing some of the mismatch between the components in the installation.
The owner probably had no supply of an offset feedhorn and adapter to clamp on the boom arm, which would most likely give similar improvements over a flat scalar system.
dan rose
1.2 meter commercial dish amiko nano, micro hd, multi lnb setup
usa indiana
This would be great for my minibud I was wondering how it would work over here. Are c band sats over here are linear plus less power. he also a lot of videos up on youtube. I have been watching several of them. SuperAlyno
PrvtN00b
The thing is, I have an offset Channel Master 1.8, would I see an improvement with this device? because I can already lock the 58w C pretty well.
blademedia
Sky
Ive not used one but I would say no, buy a chaparral feed horn and put a good quality PLL LNB on it.
Is your dish inverted ?
Have you tried a compatible/matched feed before ?
PrvtN00b
no mine didn't come with this feed horn, it came with the Ku lnb holder like shown below....
A friend here, his name is Rima sent me an adaptor for C band LNB which is working very nice so far, but it'll be cool to learn a bit more....
Thanks.
tempo
47.5N, 42.2E / Russia
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I can not say "I did not read Pasternak, but I condemn him." :-rofl2 However, from what I've tried ( I have several product from this company in Moscow ) I like very much. Actually he is not inventing LNB, but he is adopting feedhorns for them, and those feedhorns are specially designed to be installed on antennas with different opening angles (usually we speak about 70* or 90*). One of his LNBs I have now installed on my Andrew 4.6m and with that I can get UK beam from 28.5*E. So, I personally think that it is worth to have his LNBs installed.
MCelliotG
Thessaloniki, Greece
This guy has also some more very very interesting DIY mods in his youtube channel as well!
PrvtN00b
well we will need someone to translate for us to understand better his job...
RimaNTSS
N-E from Riga
@PrvtN00b if you have in mind something specific to translate I could help.
BTW, I put together his products and number is 7 plus one which is installed IMG_20170708_003631 (Large).jpg
PrvtN00b
blademedia
Sky
^^ I would listen to advise in post 4, feedsat has one of the best collections of LNBs in the hobby, he's a man to listen to,
I use this for C/KU it works very well from the test ive done, second KU band pointed at the focal point.
PrvtN00b
Anonymous_1
I remenber my emails exchange and according to the man who made these russian moddded lnb, ("Alyno") , there are better result with a 1.2m instead of a 1.8 or bigger.
Never tested on a dish smaller than 1.80m, if someone want to make a test...
