Flash crashes when uploading pics
archive10
Maybe it's a client-side thing, but I can't upload pics anymore.
Firefox tells me that Flash has crashed when trying to upload pics.
Has there been a maintenance update to the site code recently?
Mickha
North West
No problem here, when using the Upload a File option, using Firefox 52.3
Terryl
Custom built PC
TexasTech.jpg Test test test
Drag and drop works OK for me, FF 55.0.3 and W7 pro
skomedal
This and that
thule
Using Ie explorer no probs :eek:
But refuse to use this browser:-doh
Works OK using Chrome.
This using Firefox with Windows 10. Version 55.0.3 (32-bit)
image.jpeg iPad 2 and safari
pontiend
Contibruter
south yorkshire
Fine here.I seem to remember reading somewhere that firefox dose not use Flash by default.
Maybe something to do with that..
Firefox 55.3
Edit I think that that bird is one of the offspring of our White Blackbird.
archive10
I can see that this is a local problem :)
I think it's the Flash plugin, not Firefox (i'm on 55.0.2 64-bit).
The Flash version is from Aug 18, and seems to have been updated by Mint automatically.
I will try updating manually if something is available from Adobe. We'll see what happens.
4wd
Getting the picture
5 W, 9-13-19-28 E
FF 55.0.3 -without- flash, no problems, flash deleted from pc. If encountering some need for flash will open that particular site with IE which got it's special 'inbuilt' flash.
archive10
Do you upload from ie then? How do you avoid flash in firefox?
4wd
Getting the picture
5 W, 9-13-19-28 E
Hello, am using FF 99,5% exclusively. Never used anything else on this website, nor needing flash or anything special for picture upload, it just works :O)
Flash uninstalled (long time ago) from control panel > Programs and features.
If still on the pc, one can disable it in FF addons > plugins. It's disabled by default (called security risk) when installing FF.
archive10
Ah, but you're on windows, no?
I'm using Linux Mint, and it doesn't seem to work without the plug-in...
4wd
Getting the picture
5 W, 9-13-19-28 E
aaaahhhh didn't get the mint thing, can only say that ff & w needs no flash here (and less and less all over the net, youtube for example). Sorry can't help more.
archive10
Well, I took the cue, and disabled Flash altogether.
I can no longer upload multiple files, but I can upload files!
Whooohooo!
:-woohoo
I've had a couple of failed updates with the latest Firefox (55.0.3) in the past two days. It has now been installed on the laptop, but it definitely doesn't work well.
Firefox always was resource hungry and bloated and now spends to much time "Not Responding".
I have started using Edge (!!!) and it's heaps better.
That's not summat I ever thought I'd say.
No Problems here with Epic--Firefox 55.3---Chrome--Edge
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Well that is sheer desperation, I really do try to avoid Edge as it collects just so much information and I am still using Epic, but not for this post as I still have not got into the habit of checking what swmbo has opened when she 'borrows' the lappy
