Advice Needed TM-Nano SE M2 Plus Web Control
Markjose
Young one with a hobby
Triax 110 ..... No fixed location
Monmouth
Hello,
I'm looking to purchase this receiver however my question is does the unit have some sort of web control and if what control do you get?
I'm looking to move the a dish remotely using the STB, therefore won't be able to use a remote.
If someone has a guide or can give me some screenshots or similar that would be awesome.
Or if someone close to the Bracknell area has one which I can take a look at before purchasing that would be even better.
Mark
Burnham Beech
Don't understand all of your question.
All enigma2 receivers have web access either from a PC or a tablet. With a PC it is simple. Enable the webif in the menus, then enter your local IP/port in your browser.
With a tablet/phone you have can download the VU+ Player app. Although it says for VU+ boxes it will work with any e2 receiver.
Markjose
Monmouth
Which part are you un sure about?
What can be controlled from the web ui of an enigma 2 receiver ? apart from channel change ?
Quite a few things can be controlled via the Webif. Some French guy also wrote a program called Enigma TV or something like that, that you could control your box from anywhere in the World via the net. I had some succes with it too, watching recordings from my AZbox some years back.
Markjose
Monmouth
Thanks guys I will give it ago and see.
Zappas204
TechniSat Digit Cl 2 receiver , 80cm dish, universal single LNB
I understand there is a security issue with Openwebif, has this been sorted out and if so what has happened to resolve please?
