Hellas-Sat 3 @ 39°Ε
Zappas204
TechniSat Digit Cl 2 receiver , 80cm dish, universal single LNB
I prefer the non Linux Technomates as they are much easier to set up such as the TM5402HD M3,
The TM Nano SE Plus can prove very frustrating to set up due to the over complexity & unforgiving software,
That's ok if you are familiar with Linux Satellite but if you are not be aware that there is a much steeper learning curve with Linux & you will be better off with the TM5402HD M3.
Opps !! I have purchased the Nano one as I thought it was excellent value , so I guess am in for an interesting time, no idea it was difficult to set up do I need to enroll in a night class course as my understanding was that the manual/user guide will help in basic set up then I learn as I go along.
Zappas204
I must admit to being very fond of the German brand TechniSat and wanted one of their receivers, just could not find a retailer in U.K. , ahhhhh!
You should have waited for a response to your last post looks like you may end up with expensive brick.
Analoguesat & myself gave you the best advice the TM5402HD M3,
This may help you
Zappas204
I am sorry you feel that way but I simply can't believe that.
The implication being that the Nano version is a monster to set up, if that is the case then I may return it.
Please expand.
All these tps moved to Hellasat 3
12728 /12524 /12565\12606 12647/12688
And now locked successfully in Yemen
Can you give me the polarisation Horizontal/Vertical for each transponder thanks.
Please expand.
Please read through the link provided by digi247 Just Sharing This - Technomate TM-Nano-SE Quick Review
What yo need to take on board is that digi247 & some other's have been working with Linux for a long while & find setting it up easy,
For someone who is not familiar with Linux unless you are prepared to read & learn this can be a daunting task,
I do not like the TM Linux & much prefer the easy layout of the German Octagon SX 88 Linux as it is more straightforward whereas the TM Linux is not easy for a beginner & has a steep learning curve.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
Hellas Sat 2 has just a short period left @ 39 east now full transponder change over to Hellas Sat -3 will be completed within the next few days,
Then Hellas Sat-2 will move to 34.5 east for Arabsat station holding until a new Arabsat is launched to this location.
Do we expect a European beam from 34.5E?
I think it may be like Badr-4 footprint as the Hellas Sat-2 footprint is much bigger but we will have to wait & see as they will probably aim the beam further South to cover the Middle East.
Europesat
strong
Yemen
Is the thecnomate what you mentioned above support 4k (uhd) channels and cccam?
ocean04
Vaasa
Western Finland (63N 22E)
39E signal strengths here now:
Zappas204
I do appreciate all your helpful advice of the set up process proves a problem I shall return for a simpler version.
Can I set it up to receive transmission from Hellas Sat 3 initially at least then learn as I go on not plan to record at this stage. There must be a simple set up guide for beginners like me about.
I did not realise that a Linux based receiver meant that you have to be an expert in system.
Zappas204
It is the terminology that I find daunting people speak of e.g. image flashing what on Earth is that why is it required etc when you turn receiver on initially are you not guided to setting up for satellite search once you tell it what you are looking for?. These things are a challenge in any case! Please continue with your kind help.
I can only receive Ajyal TV
11557 H 2500 7/8 on the 100cm dish,
Multi-Stream received on the SX88 12593 H 9416 DVB-S2/8PSK
Below are my signals received with a 88cm dish + TM5302HD
TM5302HD 88cm Dish reception this morning.
