40.5W SES6 & NSS806
Just checked again and got a lock. No idea how viewable it would be though.
@scopus Chris might be able to have a stab at it on his 1.8 CM, he's got the extra bonus of motorised skew as well to fine tune with.
Same here, just below lock, although the S3 sees the transponder on blind scan...
nelson_b
Contributor
John,
Its an ESPN PowerVu broadcast.
I cant see "gap30" getting this one with his 1.5m Gibertini, he might be joining "The Big Dish Men" sooner than he planned if he wants to get this one in the bag?
Rgds
My result here on 1.8 c.m. offset dish with C band l.n.b. 5-6 degrees off centre .. (very marginal lock)
It seems that this particular signal is definitely outside the scope of a 1.5m dish, no hope for the small dish men.
amdade
1.5m C Band, 1.2m Channel Master offset KU, Technomate TM-6902
Norfolk, UK
On my 2.4m I find that I need to put the dielectric plate in the "wrong" way around for this TP. Im really not sure why it works, but it does. Don't forget to rescan once you try it :-) Correct way around no lock for me...
I have a GSky Hellobox hooked up to my 2.4m and works very nicely at the moment.
hitech2016
Satellites
Morrocco
ESPN
NSS806@(40,5w)
Tp: 3980V21600
Crypted PowerVu
I have attached below a copy of the table that I posted elsewhere on the forum (gap30's topic). The table covers my recent test results on 40.5W using a 1.5m dish.
Rgds
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
All ok today 1.8m dish 09.15hrs.....55 transponders:-
I managed to lock this ESPN transponder from 40.5W with a signal level of 9.1 dB on EBS Pro and 71% in dvbdream.
40.5W, PVu Encrypted, Frequency 3980 L, SR21595 (21600)
Equipment:
Precision 2.0m dish, secondary skimmed polo pipe, Titanium single output PLL LNB.
The polo pipe had to have some secondary I/D machining on a lathe to allow the Titanium LNB to fit into it. The original machined I/D of the polo pipe for the Zinwell was too narrow for the Titanium LNB.
Pictures attached below:
I forgot to include the EBS Pro signal analyser screen grab for the 40.5W transponder (3980 L, SR21600) in post 71, now attached below.
Nice result. My TBS is packed away in the loft so no idea what I'd get now but nothing has changed at the dish end.
What's a polo pipe? Is that like an AV comm polariser?
CJ,
Yes, a polo pipe is just my way of describing a polariser barrel with steps in it. There is also a pin pipe which is a polariser barrel with metal rods in it instead of steps, link and picture of pin pipe below.
Tubo Prolongador Para Lnbf Banda C Circular - R$ 78,00
Is that different to the one we were looking at the other month MB ?.
John,
Its probably a variant on the one we were looking at a few weeks ago. There are a few sellers on the Brazil equivalent of eBay selling pin pipes, some sell the pin pipe on its own, others sell it with an LNB included that the pin pipe looks to be matched to for a correct fit. The pin pipe with LNB are available with options for the LNB frequency range, both 3.4-4.2 GHz and 3.7-4.2 GHz are listed.
Links and pictures below.
Lnbf Banda C Circular Turbinado Multiponto 65 Db 12k - R$ 127,90
Lnbf Banda C Circular Turbinado - Zinwell 67 Db 15 K - R$ 120,00
frankviana
Satellites/tv
Brazil
John,
View attachment 121031View attachment 121032View attachment 121033
Yes... www.mercadolivre.com.br (eBay Brazilian)
Usatel Imports: Usatel Import.
I don't know if José (Usatel) send to Europe... skype: joseusatel
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
let us know the freight
Equipment:
View attachment 121011View attachment 121012[/QUOTE
Got lock now and a usable picture on the Hellobox. LNB has been changed to the Titanium Wideband version and a bit of careful tweaking, at leat today has been dry here...
