Help Required Wanted 2 way US mains plug adapter
davemurgtroyd
Oxford
Oxford
I need a 2 way splitter/adapter for US flat 2 pin mains plugs. Any ideas on where I can purchase or correct terminology in the US? I have tried numerous combinations of terms on ebay (US & UK) with no luck.
Required to plug two STBs (25W & 27W) into a 100W stepdown transformer.
Terryl
Custom built PC
Any of the companies importing/specialising in domestic US white goods appliances should have adapters in their inventory, the nearest one to thos property is in Addlestone.
American Appliances
Otherwise a simple pair of travel adapters will have the converter you are looking for.
aceb
Prof Tuner 7301 /
Sussex
The "correct" US terminology for a 2-socket power outlet is a "duplex outlet"
2cvbloke
Near Pontop Pike, Co. Durham
Which gets confusing when you're looking for a duplex and someone sells you a couple of semi-detached houses... :-rofl2
"Context", Dear boy, "Context":-lmao
Not necessarily - see here for example
2cvbloke
skomedal
This and that
thule
In the UK, the power sockets in a house are connected by means of ring circuits, which are protected by 32 A circuit breakers. This type of wiring is rarely used outside the UK and requires the use of fused plugs. Small appliances, like mobile phone chargers, usually have a 3 A cartridge fuse inside the plug; heavy duty appliances, such as coffee makers, have a plug with a 13 amp cartridge fuse. Almost everywhere else in the world radial circuits are used. In this system each wall socket, or group of sockets, has a circuit breaker at the main switchboard, so there is no need for plugs to be fused. As a result, if you take some foreign appliance to the UK, you can use an adaptor, but technically it must incorporate the correct value fuse. Most would have a 13 amps one, too big for computers for example.
British Standard BS 1363 requires use of a three-wire grounded and fused plug for all connections to the power mains. Two-wire class II appliances are not earthed and often have a plastic grounding pin which only serves to open the shutters of the outlet.
Type G is mainly used in the United Kingdom, Ireland, Cyprus, Malta, Malaysia, Singapore and Hong Kong.
https://www.worldstandards.eu/electricity/plugs-and-sockets/g/
We use A fuse box with a dedicated auto/load related fuses to each area of the house, also a safety cut out circuit breaker in case of overloads.
skomedal is correct - as I am sure dave knows - and that "issue" just got missed by myself. The "obvious" answer to the latter's issue is (unfortunately!) to find a US "3-prong" 2-way adapter and plug into either a UK fused mains adaptor, or use a cable connected to a suitably-fused UK "cord-outlet" fitting (as you might with a fixed appliance like a wall-mounted electric heater).
skomedal
This and that
thule
If I get electrical products from abroad not compatible to our el. plugs simply cut the plug off and connect either an earthed or unearthed as appropriate.
Prob solved unless a power adapter
2cvbloke
NO Ground/Earth! Not "good" if the equipment to be connected needs one (safety/EMC!!)!:rolleyes:
All good and well, but when the device is a two-pin plug going into a 100w step-down transformer which usually doesn't bother with an earth:
Then an earth pin is not required, which a lot of US appliances tend not to have anyway as they have their earth bonded to Neutral, as do we in the UK with TNS or TNCS supplies... :)
If the STBs are Universal voltage (E.G. 100-240v 50-60Hz), yes, lop the plugs off and fit a UK one (Black is live, White is Neutral in US colours), but if they're single voltage probably best to just stick to the stepdown transformer and the already fitted 2-pin plugs... :)
Personally, I would always make sure that US STBs with 2-pin plugs are externally earthed unless they are clearly marked as being Double Insulated - because not all US-market 115-120V 2-pin stuff has to be that and then the internal mains insulation is not as substantial as required by IEC/EN standards for 230V/240V mains supplies (different standards, and even the US 115-120V Double Insulation requirements are lower that the IEC/EN equivalent levels for 230/240V!).
PS: speaking from many years of safety assessing/testing/certifying electronic kit to both US and IEC/EN standards:rolleyes:
2cvbloke
If the stepdown transformer is an isolating one, then earthing the devices can cause more problems than it would solve in the event of a fault, and is actually better to not earth it...
If it's a tapped stepdown transformer, therefore connecting to the mains directly, then yeah, adding an earth would be a good idea, but for this you can just use a single earth wire connected between both devices and then connected to a UK plug's earth pin (E.G. in the plug of the transformer), saving the need to rewire everything and change plugs, etc.... :)
In the UK, the power sockets in a house are connected by means of ring circuits...
The new IET 18th edition wiring regulations will remove the requirement that ring mains should be the preferred option.
2cvbloke
About damned time too, the copper shortage between 1939 and 1945 that necessitated the need for the ring main ended a long time ago, radial circuits are the de-facto standard everywhere else in the world but here...
Nevertheless, there are still zillions of ring mains already in existence, and there will probably still be good reasons for some properties to be wired/rewired using them
