- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
....that went to TJ last month. £35 plus £8 postage to the UK mainland.
For Sale - Jaeger 1224 Horizon to Horizon Mount - see condition
Similar condition and again without the top cover. I do not have the front bracket that allows bolting to anything prime focus because TJ is using it to put the 1.8 together. We ran both together at his property and the gearbox is smooth and motor is almost silent . All bolts have surface corrosion on them but are perfectly useable.
Once again if I find the missing part before it's posted/collected then its yours, but really locating the other was more luck than anything.
I'll try to get some pictures up tomorrow
Thanks for looking
Thanks for looking
