- Jan 1, 2000
- Location
- North Nottinghamshire.
im new one with C band what is the c band extended this frecuencies are not listed on kingof sat or lyngsat for example.
I have a 1.8m televes dish and titanium \ zinwell lnbs. both working fine on 40.5W 55W and 58W
The phrase 'Extended C-band' is used in a couple of ways - many years ago it referred to a C-band lnb or lnbf that would go lower in frequency than the standard bottom end of 3.6 GHz .. ie: extended down to 3.4 GHz. In todays world an Extended C-band is usually known as an lnb or lnbf that covers the part of the band 4.5 GHz to 4.8 GHz. It is possible to get a C-band lnb that will cover from 3.4 to 4.8 GHz all in one unit but they are very very expensive. I use a middle of the road Norsat 8000RI which covers 3.62 to 4.8 GHz and is a reasonable price. It is also possible to buy a 4.5 to 4.8 GHz lnb or lnbf . Channels that use the band 4.5 to 4.8 GHz are listed on Lyngsat / Flysat / K.O.S etc - check listings for 40.5 West & 65 West. ** A 1.8 mtr dish will be struggling to lock any of the 4.5 to 4.8 GHz signals on a day to day basis - i use a 2.2 mtr PF dish and get reasonable performance, a 3mtr - 3.8mtr is far better suited to give reliable signal lock and a decent margin. There are some cheap Chinese extended lnb's available - see one of forum member 'Moonbase' thread somewhere.
