Windows 10 May Updates could cause problems
Due next month but could cause problems for some because the Update is likely to be blocked for users with USB drives attached to, and/or SD cards inserted in, their machines! https://www.itpro.co.uk/…/windows-10-may-2019-update-blocke…
So make sure that you disconnect any USB drives, and/or remove any SD (SDHC) cards, from the PC before any attempt (which may well be done "automatically") is made to install the update - or, of course, if you get the warning messages outlined in that article.
PS: could someone correct the thread title - should read "Windows 10 May Updates could cause problems"
TIA
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
Wow!! What an effed up resource hog...I'm so glad I stopped using Windows years ago
Hmm, not changed when I looked at it so I've tried again.
Changed here immediately after Lazarus corrected it - your internet connection must be v....e...r....y s.......l.......o........w :D
You, Sir are a Gentleman.
(Whatever the others say :-respekt)
You, Sir, are also a Gentleman because NO-ONE - absolutely NO-ONE! - has ever called ME a Gentleman before:D.
