Any one running dump 1090 willing to try an experiment?
Started afresh, new trail. Must be something amiss. Quite low, Making quite a din. We often get light aircraft circling above, not a performance like this one.
My feed is going to be down for a couple of hours as Im replacing the coax to the 1090 antenna. There are sparrows nesting in one of our boxes with young in it next to where Im working so Im taking plenty of breaks so the parents can get in to feed.
Back up and running, the badly faded interior coax that had several joins in it has been replaced by a single run of satellite exterior stuff :)
Another 7 or 8 fleet flags that Ive done since the last lot Ive posted. These are mainly private charter operators
  • New folder.zip
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Gerry55
Hi RustySpoons
Its good to see you have improved your range, do you feed into the group VRS?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Hi RustySpoons
Not at the moment as nothing has been set up permanently, as soon as I decide on what antenna I'm using and get it all installed I'll start feeding in.
Also my girlfriends parents live near an airport and have 360 LOS view so will install something up there too.
Gerry55
I would recommend a home made ADS-B Collinear Antenna.
hxxp://ei6gsb.conorfarrell.com/construction/constructing-an-ads-b-collinear-antenna/
Mine gives me a range of up to 250NM and is located on the chimney stack
Yup the home made co-co's are great - I get 225 miles on my most favourable direction (SW) despite the antenna being somewhat of a lash up on the side of the garage. The mount comprises an old scaffold leg which came out of a skip, and some bolt together tent style extension poles which came out of the rubbish at work (!)
My VRS feed will be offline over the weekend - Im away up north for a long weekend and the computer equipment will be off.
pontiend
Contibruter
south yorkshire
I am offline to for a while too.A strange ip address has turned up in Broadcast server .
Half a dozen more operator logos for anyone that wants them. Mainly private charter stuff again, but they fill a few holes in the vrs columns.
  • OperatorLogos1.zip
Still have your earlier logos to add on to mine. Thx for that, I'll get them added.
The next set of 5 operator logos to fill a few more holes in vrs. Again mainly aircraft charter operators
@Llew @pontiend
pontiend
Contibruter
south yorkshire
Thank you Analoguesat.Now all I need are some planes.:)
Im occasionally seeing 5 or 6 all in range, but thats unusual. Its normally 2 or less
Nice to see a glider soaring overhead on this fine day. Used to see several in a day back when they were tugged up by Gypsy Moths from the airfield across the way.
If you see the glider icon the right way it look like the Starship Enterprise seen from head on :-rofl2
