- May 1, 1999
- Technomate 5402 HD M2 Ci, DM7000s, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Promax HD Ranger+ spectrum analyser.
- Berkshire
I've had a few over time, and if builders/electricians are embedding cables for later use and they are not in a duct suitable for later replacement, I always recommend they use a simple tester, test before and after installation and install a backup CAT6 cable. Also found one the other day which was apparently unidirectional, in that it had to be installed with a specific end at the sat receiver end, which of course he hadn't done and it had been plastered in.
