SnelleJef
- Sep 10, 2019
- Triax 88 Inverto Black Ultra Lnb And The VU+ Zero 4K
- Belgium
OK, just wasn't sure. Mine has green plastic trims.No no no, it is definitely Fibo 120.
Thanks Rima for the comment i also forgot to mention it comes with the original polar mount and motorThere are no fake Fibo dishes... at least I did not hear about such. So, this is real Fibo 120. The price for it should be to make both, seller and buyer happy. I think you can be happy if you get the dish for 100-150 EUR. If you get it cheaper, then you can be super-happy. Nice dish!
Thanks for the comment Andy and yeah Rima is right it's definitely a 120cm there is also a 90cm philips fibo for sale might get them both if the price is right this one also comes with the original motor here are some epicturesLooks like a genuine Fibo dish but it looks smaller than a 120...maybe a 90?
Alright i didn't knew there where other mounts and motors everydyday i learn something new thanks for the help !Sure @SnelleJef , if price is acceptable then take both. Actually this polar mount and motor is not best option for Fibo 120, it is kinda weak, but should work. Some Fido 120s came with better polar-mounts and motors.
Yeah it's totaly different then all the others i have seen thanks for the pictureThat is what my Fibo 120 has. On the motor is written "Made in USA". View attachment 126920
Hard to choose thanks once again for the infoI think it is good modification..., if done properly. Then you really can attach this motor to any receiver and use Diseqc protocol to control it.
I also think, and it is IMHO, that main value of any Fibo dish it is it's subreflector, feedarm and feedhorn. Main reflectors of those nice dishes are already old and, in most cases, warped. But SUB, feedarm and feedhorn can be installed to any other offset antenna with perfect geometry.
Be shure its done properly , I know that mod very wellI think it is good modification..., if done properly. Then you really can attach this motor to any receiver and use Diseqc protocol to control it.
