Single polarity lnb
Dishy274
2.3meter c band mesh and Ultra Plus X1000HD receiver
Townsville Australia
I am removing my duel band lnbf in favor of 2 dedicated single Polarity lnbs.
As there will be no need for any voltage switching for vertical or horizontal what changes do I make in my satelitte receiver setup.
Without some pictures of what you already have, nobody will be able to advise you.
Dishy274
What about the names of equipment on site, beyond the dish type?
Are you going to use one receiver to process signals from the two separate LNB's?
If you have a twin tuner receiver then you could connect each LNB to its own input on the receiver, one input for H and one input for V. You could then have an H version of a satellite and a V version of the same satellite with signals coming from the relevant inputs.
Or, are you going to use some type of switch to merge the signals from the separate LNB's into a single input into the receiver?
Or, are you going to use two separate receivers, one receiver for each LNB?
There are several options and depending on what option you use the receiver configuration might be different.
