Hungarian tv
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Yes I’m on eutelsat 9e
Just checking:
Do you in fact have a clear picture on any 9E FTA programm?
So that it is clear that it really is a receiver issue?
Greetz,
A33
Lee graham
Hungarian tv
Bridgwater
Just checking:
Greetz,
A33
I pick up sky news and al jazeera among a few others.
Sky News doesn't come from 9E, though 9E does carry Al Jazeera.
Closest position that carries both is 13E and I suspect therein lies the root of the problem. Thor at 1W also carries both ....
The corresponding Hotbird TP carries only Scrambled Channels ....... ergo, you appear to have an alignment issue.
Do you have a motorised dish or a fixed dish ?
From your last reply it looks like you either have a fixed dish aimed @ 1° West or a poorly set up motorised system ?
Just because you see the signal bars light up on 9 east does not mean that you can watch 9 east without aiming the dish at that satellite,
It is a common misconception with fixed dish set up's see below for channels with similar frequencies that will fool you into thinking this,
Lee graham
Hungarian tv
Bridgwater
It’s a fixed dish. I get a strong signal through my meter on 9e, and it does tune in a scrambled DUNA and M1 channel. Are those channels on hotbird or Thor? If so then I could be aligned wrong.
Do a full scan on the satellite & then tell us what is in your list then I can then tell you what satellite your dish is aimed at,
You will get a strong signal on several satellites as similar frequencies are used by some satellites but you can only receive & view what your fixed dish is aimed at.
Lee graham
Hungarian tv
Bridgwater
You will get a strong signal on several satellites as similar frequencies are used by some satellites but you can only receive what your fixed dish is aimed at.
Ok I will do it this weekend
a33
XSAT410
Rebox RE-9000
The Netherlands
Other option:
Name the channels that you have picture on, each together with its frequency and polarity.
That would also give the info we need, I guess.
Greetz,
A33
Nalleman
Motala Sweden
Sweden
M1, M2, Duna and the other Hungarian channels transmitted FTA on 9E are transmitted completely scrambled on Thor at 0,8W. Since you get Sky News and Al Jazeera it seems very likely you are getting Thor 5/6 instead of Eutelsat 9B.
Can you get for e.g. M6 Suisse or W9 Suisse (12034V)? It's FTA on 9B.
When you come back Lee graham select the satellite @ 1 west or 0.8 west in your receivers memory & then scan all TV as it looks like this is where your dish is aimed.
pazitush
Once had their Conax card for M3.
Returned it at their demand because they claimed that they are not authorized any more to sell the cards abroad.
Will try to reach them again
Lee graham
Hungarian tv
Bridgwater
Ok so after doing a re-scan as suggested by all above I will list the channels I am receiving FTA.
- credo TV
Focus sat info
Galaxy4
Historia Romania HD
History Europe
Crime + investigation
Sky news
Aljazeera
CGTN
CGTN documentary
Still not receiving any of DUNA OR M1/2.
They all scan fine, scanned over 400 channels.
- credo TV
Focus sat info
Galaxy4
Historia Romania HD
History Europe
Sky news
Aljazeera
CGTN
CGTN documentary
That is from Intelsat 10-02 @ 1 west.
Nalleman
Motala Sweden
Sweden
- credo TV
Focus sat info
Galaxy4
Historia Romania HD
History Europe
Sky news
Aljazeera
CGTN
CGTN documentary
They are all on Thor 5 and Thor 6 at 0,8 W.
You must point your dish at Eutelsat 9B at 9 degrees E to get the free versions of the Hungarian channels.
Adam792
Cheltenham
As Nalleman says, you need to move your dish to point at 9°E instead of where it points currently (Thor 0.8°W) to get the FTA versions of Duna/M1/M2 etc.
Otherwise if you can't do that you'll need to get a subscription card/CAM/receiver for either Digi TV or UPC, which are the two Hungarian pay TV providers available from the satellite your dish currently points at. A basic subscription including the channels you want costs between £4 and £8 per month, but I think you'd need a contact/family in Hungary to get the subscription for you.
dejsam01
5 meter on hotbird 13east.
3 meter on amos 4 west
lagos,Nigeria
4Himdj
1.2 Laminas Dish
Rome
hello,please can you contact me...I need MTVA hungary card also
good morning
I've bought it from a romanian internet shop
I don't know if it is still available.
If you need more information please send me a pm
best regards
dejsam01
lagos,Nigeria
good morning
best regards
please how much is it...I can’t send you PM yet because I don’t have that option on my profile yet
4Himdj
1.2 Laminas Dish
Rome
I don't remember the price. I've bought from a romanian seller that now has removed from his page.
maybe it's still available.
I ask to the admin of this forum if it's possible to put the link
thank you
regards
dejsam01
lagos,Nigeria
thank you
regards
Please Can you get it for me ??...let me know If possible
