Samsung recording device advice needed
gepuk2001
virgin media
cheshire, uk
Hello all, have a new Samsung Tv.
I need a Recording device that is easy to connect, small in size as possible, and is able to use usb or HDMI.
Thanks for any replies, gepuk
Most TVs these days will allow a standard USB memory stick to work as a recorder. The larger the size the more you can record of course, but anything larger than abouut 8GB should do for non regular use.
Remember HD will use up memory four times faster than SD.
I agree with my Honourable Friend - but can you please tell us the exact Model of Samsung telly you have?
gepuk2001
virgin media
cheshire, uk
Hello all, model is QE65Q67RATXXU, thanks
According to the User Manual, the Remote has a Record Button.
Pop in a USB Stick and have a play.
gepuk2001
virgin media
cheshire, uk
Hello, thanks for the info, will look into a USB stick. It says there is no recording device attached, thanks, gepuk
2cvbloke
Near Pontop Pike, Co. Durham
A portable USB HDD would do the job if you're frequently recording, they do need to be initialised on the TV (basically formatted into something the TV can use that also prevents copying recordings onto a PC) to use them for recording so that'll be one reason for why it'll claim there's no recording device available...
gepuk2001
virgin media
cheshire, uk
Will look into usb stick, or usb had, thanks for all your help, gepuk
