Design for a Positioner with DiSEqC Decoder
harm lok
echostar / pace / aston
The netherlands
Some progress with the hardware .
With thanks to Mike Berg ... N0QBH i have used his zero detector to build a diseqc pickup for decoding the signal and decode it into my cortex environment. I have build the zero detector into a old housing off a antenuator .
Before closing it again.
Here ready and connected between the v-box and and the receiver.
I have also baked a pic for monitor the pickup with a display .
The pickup is working perfect with cables off 2-4 metres.
The only part to build is a signal meter with a voltage output.
Maybe there are already people who have build such a universal signal meter. It would be nice to design something that's detecting any receiving signal from a satellite (analog and digital) without the needed of a complicated receiver / amplifier chip..
will be continued..
Some progress with the disecq decoder
Thanks for the effort Llew.
This day i have received the complete diagram of the sr8700 (including the power supply) from a old echostar employee .
So if some people would like tho have a copy please send me a pm
That's quite a find by you harm - rare to get any Echostar service info these days, even though (or perhaps because) it's ancient stuff. Kudos to you :)
I'll PM.
harm lok
The netherlands
I have completed and justified the algorithm for the positioner software en also put it into c++ for a cortex processor. But the code uses a lot off mathematical functionality / processor power. Maybe it is better to generate a lookup table indexed in count pulses during power up off the positioner. In that way a (cheaper) M0+ cortex processor can do the job.
For people who like math , i can send the mathlab code to generate the code and this animated plot (gif) for your dish situation.
You wil need a mathlab/simulink software installed.
harm lok
The netherlands
Sorry i can not upload the gif file
The forum accepts only .jpg and .zip files for attachment, with limit to size.
harm lok
The netherlands
I have converted the file to a zip file in the attachment. Accepting gifs with the same size as a jpg can give the forum more movement.
  • PlotChannelMas12.zip
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
... and this animated plot (gif)
Why did you, instead of using one straight blue line, make this a blue line with a fixed angle in it?
I cannot think of a reason or a function for that, in the calculation.
I assume the blue line represents what I call the TopBolt of the actuator (on the dish) to the rotation axis on the mount (your blue/black dot in the gif-file).
Greetz,
A33
a33
XSAT410
Rebox RE-9000
The Netherlands
will be continued..
I'd be interested to know the progress of this project?
Greetz,
A33
harm lok
The netherlands
Greetz,
A33
Hello A33,
Unfortunately i have not been able to work for several months because of my health.
Luckily things are going a bit better so i can pick up my hobby again.
a33
XSAT410
Rebox RE-9000
The Netherlands
OK, harm,
I hope you will get better!
And when you have something to report, I'll be glad to read it.
No hurrys, though! It's just that I sometimes wonder what is happening, when there is no message anymore...
Greetz,
A33
KE4EST
Amiko 4K.UHD on Motorized STAB motor 120cm dish and 3M C-Band dish.
North Carolina, USA
Hello A33,
I hope you are feeling better Harm. Any more work on this project?
