Octagon sf8008/sf8008m mini multiboot with octagon sx88 linux os
http://www.octagon-germany.eu/
OCTAGON SF8008/SF8008m Mini Multiboot with Octagon SX88 Linux OS
The Octagon SX88 Linux OS is now also available in the recovery menu.
The image is optimized for IPTV and DRM content.
Available for the SF8008 and SF8008m Mini.
Es gibt im Recovery Menü nun auch das Octagon SX88 Linux OS
Das Image ist Optimiert für IPTV und DRM Content
Verfügbar für die SF8008 und SF8008m Mini.
SW Links for UBS installation!
SW Links für USB Installation!
SF8008m
SF8008
ocean04
Vaasa
Western Finland (63N 22E)
Tested SF8008 but it did not work. Installed to slot2 (Network Multiboot Image Upgrade)
But startup_2 is not visible and now "Slot select" is just gray and empty.
Worked OK for me off the USB. Nice to have an extra SX88 now!
Streaming to VLC does not seem to work on the SF8008 with the SX88 firmware, OK with the actual SX88 itself though. Not a big fan of Enigma2 but this has put new life in the SF8008 for me, and the ability to watch 4K with the SX88 firmware. Good job!!
SnelleJef
Triax 88 Inverto Black Ultra Lnb And The VU+ Zero 4K
Belgium
Hello install works trough usb trough network multiboot it does not work thanks @Octagon-Germany for this nice image it looks realy nice youtube and other stuff are working only satellite is not working it shows 99% quality 0% signal tested on hotbird on other images i have np with signal i have a dish with 1 lnb no motor or anything else on the OCTAGON SF8008 4K UHD HEVC Twin DVB-S2X Dual WIFI
SnelleJef
Belgium
i am using 8008 combo, satellite signal is working. twin, both tuner no signal ?
Hello twin sat tuner tried both tuners tried other sat positions nothing everything else seems working i think its only on sf8008 from what i can see from others sf8008m is working like on your youtube video also reflashed image and did firmware update but nothing
SnelleJef
Belgium
i test 8008 combo and 8008M mini combo, twin and single will test coming days too
Alright thanks for the help if others got it working please write it here thanks in advance
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10523 22-06-2020
- Low Symbol Rate improved
- Niedrige Symbolraten verbessert
- Düsük sembol hizi iyilestirildi
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10523 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10523 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10523 OK
SW offline - USB:
DUAL OS Menu:
octagon_SF8008_v1.05.23_20200622
Recovery Bootmenu (E2):
SF8008 -
octagon-sf8008-v1.05.23-20200622-mmc
SF8008m - octagon-sf8008m-v1.05.23-20200622-mmc
OCTAGON GERMANY SUPPORT
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
hi
i try with usb dont success
plz what is the steps to do
Mohd Sadoon
Coverage 14W - 125E
Oman
Mohd Sadoon
Coverage 14W - 125E
Oman
.mug you can install by usb in slot 1 als recovery flash, slot 1 e2 will lost,
e2 you can use also on slot2,3,4...
yes multibootimage install in recovery menu, as you can see in youtube video
i follow the steps in video but not working
plz tell me which file should i use
Mohd Sadoon
Coverage 14W - 125E
Oman
e2 on slot 1 is new date ?
Yes solt one is new open Atv 6.3
Network upgrade not working
How to upgrade by USB ?
Also who are use usb way plz help me to upgrade tell the steps
Also determine the specific file for the USB way
